Aruba IAP 205 The signal is weak
  • 1.  Aruba IAP 205 The signal is weak
    Posted Dec 05, 2017 07:00 AM
    Hello, I am writing in Turkey. I work in the hospital's data processing unit. We use 20 ARUBA IAP 205. We can not get the efficiency from this device. There is a modem next to the ACSESS point. The modem has a better acsess point.
  • 2.  RE: Aruba IAP 205 The signal is weak
    Posted Dec 05, 2017 09:07 AM
    - What client are you using?
    - What band is the client connecting to?
    - Are you using encryption on that SSID?
    - Do you have "Broadcast Filtering" under advanced in your SSIDs set to "ARP" or "all"?
    All of these things can affect performance.
  • 3.  RE: Aruba IAP 205 The signal is weak
    Posted Dec 07, 2017 02:19 PM
    - What client are you using? (Android OS and Windows OS)
    - What band is the client connecting to? (2.4 Ghz and 5 Ghz bands)
    - Are you using encryption on that SSID? WPA-2
     Do you have "Broadcast Filtering" under advanced in your SSIDs set to "ARP" or "all"? (I will ask the authorized company we bought the product
