I have an Aruba IAP 207 with the following configuration:
SSID 1 which is set to take the IP from the Server of the DHCP Windows
SSID 2 for guests and it takes its IP address from the Aruba IAP-207 DHCP
The problem is that I changed the old firewall with a new one from Cisco (Firepower 1010 FTD) and the Aruba IAP 207 doesn't work anymore (DHCP doesn't work, I don't have internet access)
What should I do, so that the IAP 207 takes the DHCP client from the Server and internet access too?
The old firewall does not have a special setting for ARUBA IAP 207.
When I put them (IAP-207) into operation I did not set anything on the firewall, I only configured them as it is written in the documentation.
It doesn't work with the new one.
Appreciate your help
Gerald
