Aruba IAP-215s and Avaya ERS 4800s
  • 1.  Aruba IAP-215s and Avaya ERS 4800s
    Posted Mar 25, 2015 02:11 PM
    Hello everyone,
    We are having problems setting up our IAP-215s on our new Avaya Ethernet Routing Switch 4800 switches. We have successfully configured Instant on the first IAP-215 we installed, but there seems to be a problem with the broadcast traffic when we try to connect another IAP-215 on the same switch. The second IAP-215 can't join the cluster and tries to initialize a master election on its own. We have tried the same scenario with our older Nortel switches and it worked instantly, so we are guessing there is a feature on the Avaya switches that needs to be enabled/disabled. We have checked for Storm Control and Rate Limiting features and they seem to be disabled on the Avaya switches.
    Here are the logs I have gathered with the console port on the problematic IAP-215:
    Image is signed; verifying checksum... passed
    Signer Cert OK
    Policy Cert OK
    RSA signature verified.
    [    0.000000] Flash variant: variant0
    [    0.000000]
    [    0.000000] Aruba Networks
    [    0.000000] ArubaOS Version 6.4.2.0-4.1.1.0 (build 45444 / label #45444)
    [    0.000000] Built by p4build@cartman on 2014-08-15 at 22:19:51 PDT (gcc version 4.5.1)
    [    0.000000]
    [    0.000000] P1010 RDB board from Freescale Semiconductor
    [    0.000000] Memory: 246716k/262144k available (12184k kernel code, 15428k reserved, 504k data, 358k bss, 8792k init)
    [    0.001491] Brought up 1 CPUs
    [    0.077631] PCI: Probing PCI hardware
    [    0.120682] pci 0000:00:00.0: PCI bridge to [bus 01-ff]
    [    0.183587] pci 0001:02:00.0: PCI bridge to [bus 03-ff]
    [    0.245811] pci 0000:00:00.0: not setting up bridge for bus 0000:01
    [    0.320382] pci 0001:02:00.0: not setting up bridge for bus 0001:03
    [    6.321852] fsl-ifc ffe1e000.ifc: Freescale Integrated Flash Controller
    [    6.426686] Kprobe smoke test started
    [    6.476615] Kprobe smoke test passed successfully
    [    6.640211] ee000000.nor: Found 1 x16 devices at 0x0 in 16-bit bank
    [    6.715313] Amd/Fujitsu Extended Query Table at 0x0040
    [    6.776802] number of CFI chips: 1
    [    6.821190] fsl-gianfar ethernet.2: enabled errata workarounds, flags: 0x4
    [    6.903552] gfar_probe: Renaming interface to bond0
    [    6.962314] /proc/gfar_bond0_stats created
    [    7.024537] Enabling watchdog on CPU 0
    [    7.073485] Disabled fips elf aesccm selftest
    [    7.125647]
    [    7.125651] Starting Kernel SHA1 KAT ...Completed Kernel SHA1 KAT
    [    7.217403] Starting Kernel HMAC-SHA1 KAT ...Completed Kernel HMAC-SHA1 KAT
    [    7.307237] Starting Kernel DES KAT ...Completed Kernel DES KAT
    [    7.379191] Starting Kernel AES KAT ...Completed Kernel AES KAT
    [    7.422986]
    [    7.468849] Starting Kernel HMAC SHA1 FIPS KAT ...Completed Kernel HMAC SHA1 FIPS KAT
    [    7.564132] Starting Kernel HMAC SHA256 FIPS KAT ...Completed Kernel HMAC SHA256 FIPS KAT
    [    7.667387] Starting Kernel HMAC SHA384 FIPS KAT ...Completed Kernel HMAC SHA384 FIPS KAT
    [    7.771623] Starting Kernel HMAC SHA512 FIPS KAT ...Completed Kernel HMAC SHA512 FIPS KAT
    [    7.875849] Starting Kernel AES-CBC FIPS KAT ...Completed Kernel AES-CBC FIPS KAT
    [    7.973324] Starting Kernel 3DES-CBC FIPS KAT ...Completed Kernel 3DES-CBC FIPS KAT
    Domain Name: instant.arubanetworks.com
    No panic info available
    apfcutil: sector CACHE: Cache uninitialized
    apfcutil: sector RAP: Cache uninitialized
    apfcutil: sector FAT: Cache uninitialized
    apfcutil: sector SCRATCH: Cache uninitialized
    Check backup ENV.
    apfcutil: sector MESH Prov: Cache uninitialized
    Cfg len is 0
    Configuration file is empty, turning on default services...
    extended ssid activate due to no AP config ...
    [   16.778024] ADDRCONF(NETDEV_UP): bond0: link is not ready
    Ethernet uplink not active yet
    [   22.793903] PHY: bond0 (mdio@ffe24000:00) - Link is Up - 1000/Full
    [   22.868399] ADDRCONF(NETDEV_CHANGE): bond0: link becomes ready
    Mesh is DISABLED on this device.
    [   23.149580] AP xml model 84, num_radios 2 (jiffies 11402)
    [   23.214200] init_asap_mod: installation:0
    [   23.262185] radio 0: band 1 ant 0 max_ssid 16
    [   23.314311] radio 1: band 0 ant 0 max_ssid 16
    [   23.366437] election init: rand=17 HZ=500
    [   23.414379] IAP client match init
    notify asap_mod 3g no present...
    Starting watchdog process...
    Getting an IP address...
    Dec 31 16:00:23 udhcpc[2009]: udhcpc (v0.9.9-pre) started
    Dec 31 16:00:23 udhcpc[2009]: send_discover: pkt num 0, secs 0
    Dec 31 16:00:23 udhcpc[2009]: Sending discover...
    Dec 31 16:00:25 udhcpc[2009]: send_discover: pkt num 1, secs 2
    Dec 31 16:00:25 udhcpc[2009]: Sending discover...
    Dec 31 16:00:27 udhcpc[2009]: send_discover: pkt num 2, secs 4
    Dec 31 16:00:27 udhcpc[2009]: Sending discover...
    [   29.021517] Enabling USB power
    Dec 31 16:00:29 udhcpc[2009]: No lease, forking to background.
    Dec 31 16:00:49 udhcpc[2114]: send_discover: pkt num 0, secs 26
    Dec 31 16:00:49 udhcpc[2114]: Sending discover...
    Dec 31 16:00:51 udhcpc[2114]: send_discover: pkt num 1, secs 28
    Dec 31 16:00:51 udhcpc[2114]: Sending discover...
    Dec 31 16:00:53 udhcpc[2114]: send_discover: pkt num 2, secs 30
    Dec 31 16:00:53 udhcpc[2114]: Sending discover...
    Dec 31 16:00:53 udhcpc[2114]: send_selecting: pkt num 0, secs 30
    Dec 31 16:00:53 udhcpc[2114]: Sending select for 10.3.0.101...
    Dec 31 16:00:53 udhcpc[2114]: Lease of 10.3.0.101 obtained, lease time 691200
    Dec 31 16:00:53 udhcpc[2114]: DHCP OPT 60 is not ArubaAP
    Dec 31 16:00:53 udhcpc[2114]: DHCP OPT 60 is ArubaInstantAP
    Dec 31 16:00:53 udhcpc[2114]: DHCP OPT 43, len: 44, buf: AP_Administration,10.2.0.154,***********
    Dec 31 16:00:53 udhcpc[2114]: ams-ip: 10.2.0.154, ams-key:**************
    [   54.477344] ip_time_handler: Got ip and packets on bond0 Started master election 25-0, rand 22
    10.3.0.101 255.255.252.0 10.3.0.1
    Compressing all files in the /etc/httpd directory...
    [   55.312109] Adding bridge entry for magic vlan GW, ifindex 8450, ac:a3:1e:c5:93:ee
    [   55.402784] (00:00:55) !!! Init ---> Slave
    Done.
    Starting Webserver
    bind: Transport endpoint is not connected
    Launching NTP Client on pool.ntp.org
    [   58.839617] wifi0: AP type AP-215, radio 0, max_bssids 16
    [   58.947489] wifi1: AP type AP-215, radio 1, max_bssids 16
    shutting down watchdog process (nanny will restart it)...
    Completed SW FIPS KAT test
            <<<<<       Welcome to the Access Point     >>>>>
    User: [   89.329869] asap_send_elected_master: sent successfully
    [   89.409582] wait for stm to initialize over
    [   89.459635] asap_send_elected_master: sent successfully
    [   89.542672] process `snmpd_sap' is using obsolete setsockopt SO_BSDCOMPAT
    Has anyone tried this combination of Avaya ERS 4800 switches and Aruba IAPs?
    Many thanks for your help.
  • 2.  RE: Aruba IAP-215s and Avaya ERS 4800s
    Posted Mar 26, 2015 05:58 AM
    HI,
    Please ensure that both the IAPs are in the same VLAN and master beacons are allowed that VLAN. BTW if you can share the console output we  can understand what is happening between IAPs
    and also go through the output of "show election statistics" will give idea whether both are able to exchange beacons or not.
  • 3.  RE: Aruba IAP-215s and Avaya ERS 4800s
    Posted Mar 26, 2015 10:19 AM
    Thank you very much for your help. We ended up figuring it out by ourselves:  A Virtual Controller VLAN was defined in System > General, and when we removed it the problem was solved. Though it was the correct VLAN for the Virtual Controller, it didn't seem to play nice with Avaya ERS 4800 switches.
    In case anyone wants more information, we configured the ports on the switch to be trunked with the VLANs we use for our WiFi along with the parameter "UntagDefaultPVID" which I believe is the equivalent of the "native vlan" concept for Cisco switches.
    Best regards.
