I tested it out with the latest firmware version 6.4.4.6-4.2.4.0_55341 and it works perfectly.
However, i have some more questions hopefully you guys can help to answer.
1. For this setup, any limitations of this WIFI Mesh as uplink for Wired LAN(example, limited number of MAC Address to certain numbers, ...)?
2. Is there any way that we can "view" the current bandwidth of WIFI Mesh link?
Below is some output:
IAP-Master# show aps
2 Access Points
Name IP Address Mode Spectrum Clients Type Mesh Role Zone Serial # 2.4 Channel 2.4 Power (dB) 2.4 Utilization (%) 2.4 Noise Floor (dBm) 5.0 Channel 5.0 Power (dB) 5.0 Utilization (%) 5.0 Noise Floor (dBm) Need Antenna Config From Port Config Id Config Csum Ext SSID Active Age
IAP-Master 192.168.2.40* access disable 0 225(indoor) Portal - CT0789683 1 20 18(good) -97(good) 116E 22 3(good) -97(good) No eth0 2 53725 disable 19h:16m:35s
IAP-Slave 192.168.2.3 access disable 0 225(indoor) Point - CT0789753 6 20 56(ok) -97(good) 116E 22 3(good) -95(good) No none 2 53725 disable 41m:6s
IAP-Master# show ap mesh link
Neighbor list
MAC Portal Channel Age Hops Cost Relation Flags RSSI Rate Tx/Rx A-Req A-Resp A-Fail HT-Details Cluster ID
84:d4:7e:e1:aa:30 84:d4:7e:e1:a1:71 116E 0 1 1.00 C 41m:26s VLK 81 6/6 1 1 0 VHT-80MHz-3ss 1837eea8f0cbb880cffb1ace78548ed
Total count: 1, Children: 1
Relation: P = Parent; C = Child; N = Neighbor; B = Blacklisted-neighbor
Flags: R = Recovery-mode; S = Sub-threshold link; D = Reselection backoff; F = Auth-failure; H = High Throughput; V = Very High Throughput, L = Legacy allowed
K = Connected; U = Upgrading; G = Descendant-upgrading; Z = Config pending; Y = Assoc-resp/Auth pending
a = SAE Accepted; b = SAE Blacklisted-neighbour; e = SAE Enabled; u = portal-unreachable; o = opensystem
Ha,
