Aruba IAP-225 not sending the SSID to the Cisco ACS?
  • 1.  Aruba IAP-225 not sending the SSID to the Cisco ACS?
    Posted May 03, 2016 09:35 AM
    Folks,
    I need some help with our Aruba IAP-225 device which is in a cluster. The cluster has 2 AP's in it.
    The issue we are facing is that the Aruba IAP does not seem to send the SSID with the requests it forwards to the Cisco ACS.
    I recollect a similar setting in the Aruba 7005 where we had to mention send the SSID and wanted to confirm if something similar is also present on the IAP-225.
    Any comments/help on this one?
    The ACS setting for the Aruba IAP and the Aruba 7005 is similar.
    N.
  • 2.  RE: Aruba IAP-225 not sending the SSID to the Cisco ACS?
    Posted May 03, 2016 09:43 AM
    Do you have the Aruba dictionary imported into ACS?
  • 3.  RE: Aruba IAP-225 not sending the SSID to the Cisco ACS?
    Posted May 03, 2016 10:13 PM
    Hi Tim,
    That has not been imported, is there a guide on how to do that? We are running ACS version 5.5.
    Interestingly as I mentioned earlier the Aruba controllers i.e. 7005 and 7010 work fine.
  • 4.  RE: Aruba IAP-225 not sending the SSID to the Cisco ACS?
    Posted May 04, 2016 04:33 AM
    Try the page here:  http://alec.dhuse.com/?p=15
    The attribute you are looking for is "Aruba-Essid-Name" (VSA 5).
