Aruba IAP-225 unable to communicate over Cisco switch connected by trunk to each other.
  • 1.  Aruba IAP-225 unable to communicate over Cisco switch connected by trunk to each other.
    Posted Jan 11, 2016 03:05 AM
    Folks,
    I am having some trouble getting Aruba IAP's connected over different Cisco switch into cluster.
    The master IAP is already connected on switch-01 and the second IAP is connected on switch-02.
    Both Cisco switches are connected to each other over trunk with required VLAN's allowed. However, the IAP that has to join the cluster does not join the cluster when it is connected to the second switch. When the second IAP comes back on switch-02 things start working fine and this IAP joins the cluster.
    Could there be some additional configuration needed? The configuration done on the master IAP is auto-join mode.
    Thanks!!
  • 2.  RE: Aruba IAP-225 unable to communicate over Cisco switch connected by trunk to each other.
    Posted Jan 11, 2016 04:31 AM
    This worked after resetting the second Aruba IAP-225.
