Cloud Managed Networks
Aruba IAP 315 Cloud Gesut
  • 1.  Aruba IAP 315 Cloud Gesut
    Posted Sep 16, 2019 03:27 AM
    Aruba Cloud Guest not working after sign in. Portal redirect to https://securelogin.arubanetworks.com/cgi-bin/login
    then it says "
    Connect to Wi-Fi
    The Wi-Fi you are using (xxxxx-GUEST) may require you to visit its login page.
    This works for AP303 but not for IAP207 and IAP315
  • 2.  RE: Aruba IAP 315 Cloud Gesut
    MVP EXPERT
    Posted Sep 16, 2019 05:09 AM
    Have you replaced the default certificate which is shipped with the IAPs? It was revoked and will cause warnings/issues with browsers.
    https://community.arubanetworks.com/t5/Controller-less-WLANs/ArubaOS-Default-Certificate-Revocation-FAQ-Instant/ta-p/275814
    Are all the IAPs part of the same cluster?
  • 3.  RE: Aruba IAP 315 Cloud Gesut
    Posted Sep 16, 2019 05:52 AM
    Just single IAP315 in my Office.
    How to generate CSR. is it ok use online CSR generators.
  • 4.  RE: Aruba IAP 315 Cloud Gesut
    MVP EXPERT
    Posted Sep 16, 2019 06:14 AM
    Do you have access to OpenSSL?
  • 5.  RE: Aruba IAP 315 Cloud Gesut
    Posted Sep 16, 2019 06:24 AM
    Yes, I have.
  • 6.  RE: Aruba IAP 315 Cloud Gesut
    MVP EXPERT
    Posted Sep 16, 2019 06:25 AM
    Create the CSR in OpenSSL, you'll be able to obtain all the keys as well. Once you have this information you can create and upload the certificate to your IAP.
  • 7.  RE: Aruba IAP 315 Cloud Gesut
    Posted Sep 16, 2019 11:15 AM
    Aruba Cloud Guest should redirect to securelogin.hpe.com and that certificate should be pushed automatically by Central.
    Can you check in Central that you configured the aruba_default certificate under Security - Certificate Usage - Captive Portal?
  • 8.  RE: Aruba IAP 315 Cloud Gesut
    Posted Sep 18, 2019 12:20 AM
    Problem solved after changing default certificate from Aruba central
    Thank you, Herman & Craig
