Hi Rahbar.
This is very frequent question from users. It would be much better if you ask it in Wireless Community.
The short answer is there is no web gui on AOS10. And management is possible only via Aruba Central cloud or on-prem solution. You need to have a valid subscription to this service to use AP with AOS10.
The longer answer is it depends on the FW version. You can use the same AP as Instant with Instant V8, as campus AP controlled by Mobility Controller(s) with AOS8 or as cloud only managed AP with AOS10.
For the first option Instant AP you don't need any subscriptions or licenses. You can manage it via local web GUI, via Aruba Central or via AirWave.
For second option you need a physical or virtual Mobility Controller with appropriate licenses for each AP controlled by that controller.
For third option you need Aruba Central account and subscription.
If you don't have Aruba Central subscription, then you need to flash AP with Instant V8 FW. How to do it is debated in detail in Wireless community.
Best, Gorazd
Gorazd Kikelj
MVP Guru 2024
Original Message:
Sent: Aug 13, 2024 12:49 PM
Subject: Aruba IAP 510 not getting access in GUI and default SSID not broadcasting
I have Aruba IAP 510 (OS- ArubaOS_Draco_10.6.0.2_90095) . I am getting access via console only.
I had factory reset but not getting access access via GUI and default SSID also not broadcasting.
Power light is red but WIFI light not blinking. Please help
