It is, but as it's old you may need some filters to get to it.
Original Message:
Sent: Apr 04, 2024 02:48 AM
Subject: Aruba IAP 93
Thanks for the information
Is there any way to download the 4.0 or 4.1?
It is not available in ASP
Original Message:
Sent: Apr 02, 2024 10:43 AM
The IAP-93 appears to have been parked on IAP 4.1, not supported in 4.2.
Carson Hulcher, ACEX#110
Original Message:
Sent: Apr 01, 2024 02:10 AM
Name:Aruba Operating System Software
Type: 93
Version: 6.4.2.6-4.1.3.7_71499
The IAP93 is having few issues with the following version
I tried with the following images
ArubaInstant_Orion_6.4.4.8-4.2.4
But during the upgrade, I received an "Invalid Image File" error
New files were downloaded from the ASP and I am receiving the same error
Any idea?
