Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
This thread has been viewed 30 times
  • 1.  Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    Posted May 20, 2020 01:49 AM
    Hello
    I've an IAP Cluster which has the "CONFIGURATION STATUS Unsynchronized" in Central (Select an IAP - Manage - Overview).
    Actual the cluster is only sycronized after a reboot.
    All the other clusters have the "CONFIGURATION STATUS Synchronized".
    Do you have any idea what is the problem and how can it been solved?
    Kind regards
  • 2.  RE: Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    MVP EXPERT
    Posted May 20, 2020 04:07 AM
    Is the cluster connected to Central okay? Whats the output of 'show activate' on the IAP CLI? Does each of the IAPs in the cluster have a subscription assigned within Central?
  • 3.  RE: Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    Posted May 20, 2020 05:42 AM
    The show activate command show the following:
    Activate Server: device.arubanetworks.com
    Activate Status: success
    Aruba Central Server: device-prod2.central.arubanetworks.com
    I can have access via central to the IAPs so I think the connection is good but there is an issue with the Sync.
    Firmware Version is: 8.5.0.5_73491
  • 4.  RE: Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    MVP EXPERT
    Posted May 20, 2020 05:46 AM
    Can you provide the output of the following? Also to confirm based on your first message, the IAP is sync'd but only after a reboot? What happens/time duration does it take for it to show unsync'd?
    show ap debug cloud-config-received
    show ap debug cloud-data-sent
    show ap debug cloud-state
  • 5.  RE: Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    Posted May 20, 2020 06:13 AM
    Unfortunately I don't know if the status is Syncronized after the reboot and change then to unsyncronized. But I can see that the last conig Changed is when I was rebooting them.
    show ap debug cloud-config-received:
    timestamp: 2020-05-19 18:50:00
    Airgroupservice airprint: OK
    : Syntax error, skipped
    exit: OK
    show ap debug cloud-data-sent:
    there is no Output from this show command received
    show ap debug cloud-state:
    A liste of all Clients which are connected to the cluster is received. here I put an example:
    <MIB_CLIENT_TABLE> MIB_IS_WIRED(95) = 0
    MIB_MAC_ADDRESS(1) = xx:xx:xx:xx:xx:xx
    MIB_NAME(2) = xxxxxxxxx
    MIB_IP_ADDRESS(5) = 172.29.60.107
    MIB_PHY_TYPE(19) = 1
    MIB_HT_TYPE(20) = 5
    MIB_BSSID(31) = xx:xx:xx:xx:xx:xx
    MIB_SNR(48) = 11
    MIB_RX_RETRIES(49) = 0
    MIB_TX_RETRIES(50) = 163
    MIB_OS_TYPE(53) = Apple
    MIB_USER_ROLE(80) = xxxxxx
    MIB_IPV6_ADDRESS(137) = xxxx::xxx:xxxx:xxx:xxxx
    MIB_VLAN(27) = 601
    MIB_CLIENT_AUTHTYPE(135) = 0
    MIB_CLIENT_AUTHSTATE(136) = 0
    MIB_CLIENT_ACTIVE_STATUS(140) = 1
    </MIB_CLIENT_TABLE>
  • 6.  RE: Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    Posted May 27, 2020 04:29 AM
    Is there anyone who have idea whats the solution of the problem?
  • 7.  RE: Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    Posted May 27, 2020 10:41 AM
    Did you try to check the Audit Trail from Central? Any hints there?
    If you can't find any hint there, can you try to open a case with TAC?
  • 8.  RE: Aruba IAP Cluster CONFIGURATION STATUS Unsynchronized
    Posted Jun 02, 2020 02:00 AM
    There are no hints in the Audit Trail.
    Since last week one of the cluster has now the status Synchronized again (without any change from my site).
