Aruba IAP guest user ID creation.
  • 1.  Aruba IAP guest user ID creation.
    Posted Dec 15, 2015 05:12 AM
    Folks,
    We have a IAP-225 cluster ready for our employee access. We are looking to add the Guest Wireless support for this.
    I see a User ID by the name "Guest Registration Only" and I understand that this ID can have the rights to create new guest users, correct?
    If the above is correct, how can I go about creating Guest ID via CLI? Any document to create guest ID?
    N.
    #AP225
  • 2.  RE: Aruba IAP guest user ID creation.
    Posted Dec 15, 2015 06:07 AM
    Here;s the command:
    IAP-2 (config) # mgmt-user <username> <password> guest-mgmt
  • 3.  RE: Aruba IAP guest user ID creation.
    Posted Dec 16, 2015 08:51 AM
    Thanks Victor. This has been done through the GUI, I verified and the command is the same.
    Here is my challenge now. We have already enabled TACACS authentication for the IAP-225 box, and the TACACS authentication superseeds the local authentication configured.
    Is there any solution to this? As our local authentication which is used for Guest provisioning is unable to login due to this TACACS superseeding.
  • 4.  RE: Aruba IAP guest user ID creation.
    Posted Dec 16, 2015 09:05 AM
    There's an option to use local fallback auth
