aruba iap mac address error (deny all role..)
  • 1.  aruba iap mac address error (deny all role..)
    Posted Jun 03, 2016 10:01 AM
    Hi all, i have 7 IAP (4 x IAP93 and 3 x IAP205).
    IAP93 use a specific zone, so i can deploy an SSID only to this group of IAP.
    Now i'm trying to deploy an SSID with WPA2 + MAC AUTH using internal db.
    So i prevently added a test user (MAC in username field and password field) without delimiter in user list (selecting employee, not guest)
    Then made an SSID in 2,4 ghz , but when i try to connect by my smartphone i can't connect (smartphone try to connect in loop, one time i 've see a client connected but with DENY ALL role)
    If i remove MAC AUTH, wifi is ok instantly
    What i can check?
    I can't try now making SSID on IAP205 instead of IAP93
    This is current firmware 6.4.2.6-4.1.1.7_50209, IAP93 is master virtual controller
    Ask me for details, really thanks!
    mattia
  • 2.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 03, 2016 10:09 AM
    The IAP-93 does not support mac authentication in the 4.1.x.x versions of code: (MAC authentication uses the Internal Radius Server).
    http://community.arubanetworks.com/t5/Software-Downloads/Aruba-Instant-6-4-2-6-4-1-1-10-Released-9-28-15/ta-p/255141
  • 3.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 03, 2016 10:16 AM
    Thanks...so it doesn't work also if i update to latest version?
    (system notify there's a new update available -> 6.4.2.6-4.1.11_52666)
    I have to change IAP93 with a newer model or using a RADIUS\LDAP server?
    Mattia
  • 4.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 03, 2016 10:20 AM
    It will not work on IAP-93s, even if you update, unfortunately.  You can use an external radius  or LDAP server to get around this, however.
  • 5.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 03, 2016 10:28 AM
    Ok..last thing please.
    I have to create object  with mac adress username\password in LDAP server,
    then connect aruba virtual controller to LDAP using objectfilter?
    can you provide me a link to specific document?
    thanks again
    Mattia
  • 6.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 03, 2016 10:32 AM
    - Create an LDAP server using the instructions here:  http://community.arubanetworks.com/t5/Controller-less-WLANs/How-to-configure-LDAP-authentication-on-the-Instant-for-the/ta-p/181130
    - Change the Authentication for mac address to point to that LDAP server.
  • 7.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 04, 2016 03:12 PM
    ok.i see ldap is not the best solution, maybe i need to think about a radius server
  • 8.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 04, 2016 03:48 PM
    If you have a Windows Server, you already have a free radius server that you can install...  (IAS or NPS).
  • 9.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 04, 2016 05:13 PM
    my "chain" is made by 4 x IAP93 and 3 x IAP205
    virtual master controller now is the third IAP93
    what if i force master controller onone IAP205?
    there's the same limitation about MAC AUTH feature?
    thanks again
    now i'm going to accept your answer..
    Mattia
  • 10.  RE: aruba iap mac address error (deny all role..)
    Posted Jun 05, 2016 09:01 AM
    It will not work if your user is trying to associate to an AP93.  Making the AP205 a preferred master does not change this, unfortunately...
