Aruba IAP Mesh
  • 1.  Aruba IAP Mesh
    Posted May 08, 2019 03:20 PM
    Hello all,
    With IAP is there a maximum of mesh portals in a single cluster.
    I have read that the maximum hop count is two nodes (point >point >portal) and the maximum number of mesh points per mesh portal is eight but is there a maximum number of portals?
  • 2.  RE: Aruba IAP Mesh
    Posted May 08, 2019 05:45 PM
    No you can have as many portals as you want, just note though that you don't have control over the topology or converge structure with an Instant VC, since all the mesh APs will have the same MSSID.
