Aruba IAP Mesh Mac addresses
  • 1.  Aruba IAP Mesh Mac addresses
    Posted Jul 05, 2019 10:44 AM
    Hello all,
    I am trying to work out the toplogy for an IAP mesh network but I'm having a couple of problems.
    How do I see the Mac address of the mesh SSID. If I do a show bss-table the IAP doesn't show the Mac that it is using on the mesh portal.
    I am also using show AP mesh link to other AP's to work out the mesh but the Mac addresses of the portal's don't show in the BSS table.
    I wish are was an easier way by using the AP name or somthing graphical in central but I haven't found anything.
  • 2.  RE: Aruba IAP Mesh Mac addresses
    MVP EXPERT
    Posted Jul 05, 2019 11:17 AM
    Ignore, you've already tried this! :)
  • 3.  RE: Aruba IAP Mesh Mac addresses
    Posted Jul 05, 2019 11:53 AM
    show ap mesh neighbor will show parent/children BSSID
    Mesh visualization is coming in a later version of Central (it's being worked on as we speak)
  • 4.  RE: Aruba IAP Mesh Mac addresses
    Posted Jul 05, 2019 12:06 PM
    Thanks for the replies.
    Yes I think that shows what I need, I can also sort of work it out using the 5Ghz channels. I am surprised that the way some AP’s have meshed together. 1 AP has chosen a portal which is quite a long distance away and there are two much closer.
  • 5.  RE: Aruba IAP Mesh Mac addresses
    Posted Jul 05, 2019 05:39 PM
    Much of it is a race condition, if the far portal was up before the others, or the others rebooted, that could explain part of it. If the intenst is to control the topology, you can define the mesh cluster used between points and portals.
  • 6.  RE: Aruba IAP Mesh Mac addresses
    Posted Jul 05, 2019 06:07 PM
    Hi Jerrod, in an IAP cluster I thought that the mesh forming was automatic with no control, how can we control which AP portals mesh with which points?
    When the mesh is formed don't the AP negotiate a better path / link occasionally?
  • 7.  RE: Aruba IAP Mesh Mac addresses
    Posted Jul 05, 2019 08:57 PM
    we have much better mesh control in instant version 8.4.x
    Here are the new enhancements
    1. Role Assignment enhancement for Mesh point to send loop detection packets for IAPs that are in Mesh point role before turning them back to Mesh portal IAPs.
    2. We can now have more than one mesh cluster in an IAP swarm and manually configure mesh clusters and assign it to specific IAPs
    3.  IAPs in Standalone Mode can now connect to a mesh cluster
    Check this technote.
    https://community.arubanetworks.com/t5/Controllerless-Networks/Wireless-Mesh-enhancements-with-Instant-8-4/td-p/536790
  • 8.  RE: Aruba IAP Mesh Mac addresses
    Posted Jul 06, 2019 05:06 AM
    Great stuff. In the tch note I have found the command
    sh ap mesh cluster topology
    This shows exactly what I wanted! The commands isn't in Central troubleshooting but when I SSH and run it to the VC it shows the output I wanted.
