Aruba IAP Mixed AP Upgrade
  • 1.  Aruba IAP Mixed AP Upgrade
    Posted Apr 24, 2015 06:01 AM
    We have a customer with 10 x IAP-105 and 40 x IAP-115 in the same Instant cluster. They are all running the same version of code and all is working. The VC is on the IAP-115.
    Is there an easy process of upgrading both the IAP-105's and the IAP-115's at the same time. At the moment they are physically removing the 105' and upgrading them on a stand alone network then reinstalling them.
  • 2.  RE: Aruba IAP Mixed AP Upgrade
    Posted Apr 24, 2015 08:49 AM
    You should be able to ugrade using http ftp or tftp.  Directly uploading the file is only available for clusters with the same model access point.  Again, you can use http, ftp or tftp for access points with multiple classes:  http://www.arubanetworks.com/techdocs/Instant_41_WebHelp/InstantWebHelp.htm#UG_files/IAP_maintenance/Firmware_Image_Server_in.htm?Highlight=upgrade
  • 3.  RE: Aruba IAP Mixed AP Upgrade
    Posted May 21, 2015 11:11 AM
    If the customer has different models of AP in the same cluster is there a way of upgrading them without removing them and splitting the cluster etc?
  • 4.  RE: Aruba IAP Mixed AP Upgrade
    Posted May 21, 2015 12:26 PM
    Hi ,
    Yes it is possible through Airwave or by specifying URL to download the Image according to the Hardware if IAPs are connected to Internet
    Please feel free if any further help needed on this
  • 5.  RE: Aruba IAP Mixed AP Upgrade
    Posted May 21, 2015 12:31 PM
    HI
    Please look at this,
