Aruba IAP Radio Mac Address
This thread has been viewed 24 times
  • 1.  Aruba IAP Radio Mac Address
    Posted Nov 25, 2020 11:13 AM
    Is there a CLI command that I can run to find the physical MAC address of and Aruba IAP Radios?
    Jason
  • 2.  RE: Aruba IAP Radio Mac Address
    MVP GURU
    Posted Nov 25, 2020 06:47 PM
    You can run the "show ap bssid-table" command to see what the BSSID MAC address is for each of your WLANs.
    Dustin Burns
  • 3.  RE: Aruba IAP Radio Mac Address
    MVP GURU
    Posted Nov 25, 2020 06:56 PM
    Or, if you need the base radio MAC use the following :
    show ap debug radio-info 0 | i cur_etheradd
    show ap debug radio-info 1 | i cur_etheradd
    The cur_etheradd will be your base radio MAC
    Dustin Burns
  • 4.  RE: Aruba IAP Radio Mac Address
    Posted Nov 26, 2020 06:15 AM
    Hi Dustin, thanks for this!
    Jason
  • 5.  RE: Aruba IAP Radio Mac Address
    Posted Nov 26, 2020 06:49 AM
    I found another command which fitted my needs perfectly
    show cluster bss-table
    The lowest Mac address is the Mac of Radio 1 (2.4Ghz) The Mac of Radio 0 (5Ghz) is 16 decimal / 10 Hex higher.
    Jason
