Aruba IAP VRRP
  • 1.  Aruba IAP VRRP
    Posted Aug 02, 2017 09:13 AM
    I am programming a large amount of Aruba IAP 325 access points for a customer that we normally provide controller based solutions for and I am having some issues mimicing our controller config onto an IAP. I know it is impossible to get all of the features, but I would figure VRRP settings would be pretty standard unfortunately I am unable to find any VRRP settings or settings to mimic what I do with VRRP on our aruba controllers.
    We run the following commands on our Aruba controller:
    vrrp 129
      priority 110
      authentication [Password]
      ip address xx.xx.xx.xx
      vlan 129
      preempt delay 0
      tracking master-up-time 30 add 20
      no shutdown
    vrrp 118
      priority 110
      vlan 118
      preempt delay 0
      no shutdown
    I am sure it is somewhere obvious, but Is there a way to mimic these specific commands function within the aruba IAP?. Authentication is absolutely needed.
  • 2.  RE: Aruba IAP VRRP
    Posted Aug 02, 2017 09:15 AM
    Why is the VRRP needed?
  • 3.  RE: Aruba IAP VRRP
    Posted Aug 02, 2017 09:23 AM
    From what I understand they use 129 for master redundancy and they tie VRRP 129 into the following command:
    master-redundancy
    master-vrrp 129
    peer-ip-address xx.xx.xx.xx ipsec [Password]
  • 4.  RE: Aruba IAP VRRP
    Posted Aug 02, 2017 09:28 AM
    You can create a virtual IP on the IAP management subnet that the virtual controller will always answer to. If that AP goes down, another IAP in the cluster is elected as the virtual controller and will immediately answer to that IP address. That construct replaces master redundancy.
  • 5.  RE: Aruba IAP VRRP
    Posted Aug 02, 2017 09:34 AM
    I figured this would be the answer to 129 after thinking about it, but for 118 I think they use this VRRP authentication for their captive portal I see a command for:
    ip cp-redirect-address
    Pointing back to the same IP as the VRRP setup for 118 which is their VLAN for the guest network.
  • 6.  RE: Aruba IAP VRRP
    Posted Aug 02, 2017 09:51 AM
    The internal captive portal page on IAP is rudimentary. If you want it to look good the page would be hosted on an external web server. There is no IP cp-redirect equivalent in IAP.
  • 7.  RE: Aruba IAP VRRP
    Posted Aug 02, 2017 09:59 AM
    Thanks a lot for your help I guess I just needed a second set of eyes
