Aruba IAP315 not joining cluster/fully booting
  • 1.  Aruba IAP315 not joining cluster/fully booting
    Posted Mar 18, 2019 03:09 PM
    Hello all,
    We are in the process of changing all of our access points to IAPs and have been configuring them. We had successfully confgured multiple IAP 305s and a 304 by having them boot with DHCP and then assigning a static address later one, they were all in the same vlan and broadcasting the same SSIDs.
    On the 315, I changed the address and followed the same steps as with the other ones but the IAP will not show up inside the virtual controller. I can type in the address of the 315 into a browser and it will route me to the GUI of the virtual controller but the AP will not be listed with the cluster. The system status light is green/flashing so I think the boot is finished.
    I tried to upgrade the firmware on all the IAPs and the result is the same.
    Does anyone know what might be causing this?
  • 2.  RE: Aruba IAP315 not joining cluster/fully booting
    Posted Mar 18, 2019 03:11 PM
    What version of Instant is your existing cluster?
  • 3.  RE: Aruba IAP315 not joining cluster/fully booting
    Posted Mar 18, 2019 03:17 PM
    6.5.4.8_65873 Ursa
    One of the 315s was on 6.5.4.3 Hercules and the other 8.3.0.6 Hercules.
    Thanks for the quick reply.
  • 4.  RE: Aruba IAP315 not joining cluster/fully booting
    Posted Mar 18, 2019 04:05 PM
    Did you try to downgrade them both to 6.5.4.8?
  • 5.  RE: Aruba IAP315 not joining cluster/fully booting
    Posted Mar 18, 2019 04:21 PM
    I upgraded to master IAP305 to 8.3.0.6 and now they are working and seeing eachother.
    Thank you
