aruba IAP/Airwave De-Auth after 1 hour
  • 1.  aruba IAP/Airwave De-Auth after 1 hour
    Posted Jul 11, 2019 02:36 PM
    hello,
    we are running IAP clusters and Airwave is managing them (no controller)
    our guest network has devices connect for hours sometimes.
    is there a way to say after 1 hour deauth? and make them log back in to the CP ?
  • 2.  RE: aruba IAP/Airwave De-Auth after 1 hour
    MVP EXPERT
    Posted Jul 11, 2019 04:34 PM
    What is doing the authentication for your CP/Guest Network, is this the internal DB on the IAP or an external source?
  • 3.  RE: aruba IAP/Airwave De-Auth after 1 hour
    Posted Jul 11, 2019 04:56 PM
    the CP (for this guest SSID) is local to the IAP it does not use our clearpass or anything.
  • 4.  RE: aruba IAP/Airwave De-Auth after 1 hour
    Posted Jul 11, 2019 06:55 PM
    you can enable "deauth inactive clients", which is under configuration for a specific SSID. this will be visible if you click on "show advanced options"
    Also note that the "inactivity timeout" is by default set to 1000 sec. you can change that to suit your env.
