aruba instance installation
  • 1.  aruba instance installation
    Posted Mar 31, 2016 01:37 PM
    Hi, sorry if this question could appear stupid but i didn't find a good answer.
    Last year I used aruba istant in an organization. I found this application already installed and I learned to use it (better..I learned some of the features of the application).
    Now I work for another organization. I didn't find an answer to these questions.
    Is Auba Istant a free application to download? Does it works with any sort and with all models of access point?
    Thanks a lot
  • 2.  RE: aruba instance installation
    Posted Mar 31, 2016 01:45 PM
    The Aruba Instant software only runs with Aruba Instant Hardware..
  • 3.  RE: aruba instance installation
    Posted Mar 31, 2016 06:28 PM
    So all the IAP models run instant software. The AP models need a controller
