aruba instant 2 ap mesh, only the master give ip
  • 1.  aruba instant 2 ap mesh, only the master give ip
    Posted Apr 25, 2018 10:12 AM
    Hi guys, first sorry for my english.
    My problem is: we have 2 (APIN207) ap, i would like to use them in mesh, but after i set it, only the master give ip address, if I connect to it, the authentication seems like ok, and my device waiting for ip address.
    The extended ssid is disabled, from the virtual controller I see both ap, if I can create an open ssid, but nothing changes. Anyone has any idea?
  • 2.  RE: aruba instant 2 ap mesh, only the master give ip
    Posted Apr 25, 2018 10:14 AM
    In the SSID, set the VLAN to Virtual Controller assigned.
  • 3.  RE: aruba instant 2 ap mesh, only the master give ip
    Posted Apr 25, 2018 10:33 AM
  • 4.  RE: aruba instant 2 ap mesh, only the master give ip
    Posted Apr 25, 2018 10:35 AM
    Set the client VLAN assignment to default
  • 5.  RE: aruba instant 2 ap mesh, only the master give ip
    Posted Apr 26, 2018 02:03 AM
    Thanks, it works now. But I have 2 ssids, 2 vlans, 2 dhcp scopes (wpa2 authentication for for phones, guests, only internet acces - and an radius, wich can acces the lan and the internet ). I think, I need to reconsiderat it, because in the vlan client assiggment will not work.
  • 6.  RE: aruba instant 2 ap mesh, only the master give ip
    Posted Apr 26, 2018 09:03 AM
    What is providing dhcp, the Instant AP?
  • 7.  RE: aruba instant 2 ap mesh, only the master give ip
    Posted Apr 26, 2018 09:11 AM
    yes, I had 2 ssids, 2 dhcp scopes, 2 vlans in the instant. It's works now with 2 ssid, without vlan, with 1 dhcp, with the rules i can configure the acces.
