Aruba Instant 207 Site Survey Issue
  • 1.  Aruba Instant 207 Site Survey Issue
    Posted Jul 20, 2017 03:14 AM
    Hello All,
    I have a site survey using my Aruba Instant 207 AP, how could i enforce it to work without DHCP, and how to encrease my antinna power to a high power?
  • 2.  RE: Aruba Instant 207 Site Survey Issue
  • 3.  RE: Aruba Instant 207 Site Survey Issue
    Posted Jul 20, 2017 05:01 AM
    Thanks for quick reply :)
    Where could i find (Disable SSID on Uplink failure) it is not appeare on the SSID advanced sitting?
    I want to transmit the maximum powre from my access point, what is the limit for 2.4 and 5 GHz and from where could i change it?
  • 4.  RE: Aruba Instant 207 Site Survey Issue
    Posted Jul 20, 2017 05:09 AM
    What version of InstantOS are you running?
    You set the Power under RF> ARM.
  • 5.  RE: Aruba Instant 207 Site Survey Issue
    Posted Jul 23, 2017 10:13 AM
    IAP 207 Firmware : 6.5.1.0 - 4.3.1.0
    Please view the photos attached which one of them is the right place to change the antinaa power?
  • 6.  RE: Aruba Instant 207 Site Survey Issue
    Posted Jul 23, 2017 11:16 AM
