Aruba Instant and Airwave
  • 1.  Aruba Instant and Airwave
    Posted Mar 03, 2012 06:09 AM
    Hello everyone.
    what kind of configuration we did from airwave to IAP's.
    1- Can we reboot any IAP from Airwave
    2- Can we reboot or dis associate any user from IAP from  Airwave.
  • 2.  RE: Aruba Instant and Airwave
    Posted Mar 05, 2012 04:00 AM
    You can reboot all the APs in an Instant network (via the master AP's manage page), but currently you cannot reboot individual APs from Airwave.
    Airwave does not currently support disassociating users on Instant.
  • 3.  RE: Aruba Instant and Airwave
    Posted Mar 06, 2012 12:18 PM
    actually i'd performed reboot IAP activity couple of day back with Airwave 7.4 but this function is disable in 7.3.8 (32-Bit).
  • 4.  RE: Aruba Instant and Airwave
    Posted Mar 07, 2012 03:07 AM
    Yes, that feature was added in 7.4.
  • 5.  RE: Aruba Instant and Airwave
    Posted Mar 08, 2012 10:09 AM
    Dear Muir,
    can you share the updated feature of 7.4 aspecially related to IAP's?
    What kind of configuration we performed from Airwave? please explain in length or share any document
  • 6.  RE: Aruba Instant and Airwave
    Posted Mar 08, 2012 09:15 PM
    Here are the Instant related features in the 7.4 release notes (available at support.arubanetworks.com):
     AMP now collects and processes IDS and authorization failure events from Aruba Instant IAPs in the
    same way as other SNMP traps. These events can be found in the Device Event log.
     AMP now supports Aruba Instant firmware version 6.1.2.0-2.0.0.0 which contains configuration template
    updates. Multi-platform image upgrade is now supported for Aruba Instant 6.1.2.0-2.0.0.0_30206.
     Aruba Instant uptime is now tracked.
     IAPs in an Aruba Instant implementation can be rebooted all at once in AMP.
