Aruba Instant and AppleTv
  • 1.  Aruba Instant and AppleTv
    Posted Feb 18, 2013 01:23 PM
    We are using Aruba 105's in a school enviroment. We have a flat network no VLANs. We are using roles to restrict where a student can get on our network when they are using a device they brought from home. Currently they are allowed Http and Https. The Apple TV is hardwired into our network again Flat Network. Problem is we need the students to be able to connect to the apple tv from their iPads. I have opened every port I can find related to apple Bonjour service and the best I get is a connection that lasts aprox 30 sec.
    If someone can point me in the right direction for how to setup to restrict my students by still have apple work it would be very much appreciated.
    Oh I am running firmware 6.2.0.0-3.2.0.1_36989
    Thanks In advance
  • 2.  RE: Aruba Instant and AppleTv
    Posted Feb 18, 2013 04:44 PM
    does it work when you block NO ports?
  • 3.  RE: Aruba Instant and AppleTv
    Posted Feb 18, 2013 04:47 PM
    Yes works great if I leave it open
  • 4.  RE: Aruba Instant and AppleTv
    Posted Feb 18, 2013 04:59 PM
    Which ports did you open in the first place?
  • 5.  RE: Aruba Instant and AppleTv
    Posted Feb 19, 2013 08:34 AM
    All that was open first was 80 443, 53, and DHCP
    Then in an effort to get Aple TV working I have opened
    TCP 123, TCP 3689, UDP 5353, TCP 7000, TCP 7001
    These were are open to all dest
  • 6.  RE: Aruba Instant and AppleTv
    Posted Feb 19, 2013 08:39 AM
    Sorry not port 7001 its 7100.
  • 7.  RE: Aruba Instant and AppleTv
    Posted Feb 19, 2013 09:07 AM
    You might want to send a quick email to Apple to make sure you are not missing something like ipV6
  • 8.  RE: Aruba Instant and AppleTv
    Posted Feb 19, 2013 09:14 AM
    I emailed apple and this was the response. I wasn't impressed.
    "AirPrint and Apple TV use the Bonjour protocol to communicate. Its not port based. This may help"
    They referred me to an Aruba document on AirGroup..
    Thanks for your responses in the mean time.
  • 9.  RE: Aruba Instant and AppleTv
    Posted Feb 19, 2013 09:11 AM
    I found another port in a AirPlay Protocol Document Port 49152. This appears to be the key
    Ports I have open now are
    TCP 49152
    TCP 7000
    TCP 123
    TCP 3689
    TCP 80
    TCP 443
    TCP 53
    UDP 5353
    Will update when I has been put to test. :)
