Aruba Instant and Radius CoA
  • 1.  Aruba Instant and Radius CoA
    Posted May 24, 2016 03:46 PM
    I'm decently familiar with the Aruba Instant APs and their deployment from selecting them in a previous role.  I'm now considering selecting them as our solution for our remote office locations, however we're running into a holdup.  We have a NAC vendor that we're not willing to change (Forescout) and while they state they support IAPs, they can't really do much with them, not even a simple block at the moment.
    They are pushing us away from CoA as a solution, but I spun up a freeradius box to experiment with what I can do through the Instants using CoA.
    I seem to get a success message when I issue a disconnect, but I don't appear to drop offline.  Maybe I"m just immediately reauthenticationg.  I've tried to use a CoA to switch to a different VLAN, I receive a CoA Ack but the VLAN doesn't change.
    I was wondering if anyone knows what you can and cannot do through CoA, and if there are any guides to supported and unsupported commands to be sent to the Virtual Controller.
    Thanks so much for your help!
    Chris
  • 2.  RE: Aruba Instant and Radius CoA
    Posted May 24, 2016 03:53 PM
    Can you post the contents of your CoA request?
  • 3.  RE: Aruba Instant and Radius CoA
    Posted May 24, 2016 03:59 PM
    Sure, here's from the example of trying to locate the session and update the VLAN:
    (7) Sending CoA-Request packet to host 172.20.96.247 port 3799, id=88, length=0
    (7) NAS-IP-Address = 172.20.96.247
    (7) Framed-IP-Address = 172.20.255.53
    (7) Aruba-User-Vlan = 132
    (7) Proxy-State = 0x3431
    Sending CoA-Request Id 88 from 0.0.0.0:37363 to 172.20.96.247:3799
    Waking up in 0.3 seconds.
    Received CoA-ACK Id 88 from 172.20.96.247:3799 to 172.20.254.83:37363 length 32
    NAS-Port-Type = Wireless-802.11
    (7) Received CoA-ACK packet from host 172.20.96.247 port 3799, id=88, length=32
    (7) NAS-Port-Type = Wireless-802.11
    (7) # Executing section send-coa from file /etc/raddb/sites-enabled/coa
    (7) send-coa {
    (7) [ok] = ok
    (7) } # send-coa = ok
    (7) Sending CoA-ACK packet to host 127.0.0.1 port 40820, id=41, length=0
    Sending CoA-ACK Id 41 from 127.0.0.1:3799 to 127.0.0.1:40820
    (7) Finished request
    Here's from trying just to disconnect:
    (8) Sending Disconnect-Request packet to host 172.20.96.247 port 3799, id=201, length=0
    (8) NAS-IP-Address = 172.20.96.247
    (8) Framed-IP-Address = 172.20.255.53
    (8) Proxy-State = 0x313537
    Sending Disconnect-Request Id 201 from 0.0.0.0:37363 to 172.20.96.247:3799
    Received Disconnect-ACK Id 201 from 172.20.96.247:3799 to 172.20.254.83:37363 length 32
    (8) Received Disconnect-ACK packet from host 172.20.96.247 port 3799, id=201, length=32
    (8) NAS-Port-Type = Wireless-802.11
    (8) # Executing section send-coa from file /etc/raddb/sites-enabled/coa
    (8) send-coa {
    (8) [ok] = ok
    (8) } # send-coa = ok
    (8) Sending Disconnect-ACK packet to host 127.0.0.1 port 52487, id=157, length=0
    Sending Disconnect-ACK Id 157 from 127.0.0.1:3799 to 127.0.0.1:52487
    (8) Finished request
  • 4.  RE: Aruba Instant and Radius CoA
    Posted May 24, 2016 04:16 PM
    For the VLAN change, try returning: IETF: Tunnel Type 13 and IETF:
    Tunnel-Private-Group-ID <VLAN-ID>.
    For the disconnect requests, this simply causes clients to re-authenticate.
    You'll need something your authentication policy to take different action
    when the device authenticates.</VLAN-ID>
  • 5.  RE: Aruba Instant and Radius CoA
    Posted May 25, 2016 08:37 AM
    Thanks for the reply, I've tried to do that, but didn't see a VLAN change. I'm including a snip from Wireshark of my CoA packet to make sure it's formatted as you'd expect it to be.
  • 6.  RE: Aruba Instant and Radius CoA
    Posted Jun 20, 2018 09:54 AM
    Ciao,
    does the CoA use the client IP address for disconnecting ? And not the client MAC address?
