Aruba Instant and TACACS or TACACS+ support
  • 1.  Aruba Instant and TACACS or TACACS+ support
    Posted May 17, 2019 10:22 AM
    Hi community,
    I want to verify something. As far as I read in the Aruba Instant manual, you can configure RADIUS or TACACS authentication servers to authenticate and authorize the management users of an Instant AP.
    My question is: does it refer to TACACS or TACACS+ server?, are both supported?, is just only one supported?
    Maybe Aruba guys can confirm me this.
    Thanks in advance
  • 2.  RE: Aruba Instant and TACACS or TACACS+ support
  • 3.  RE: Aruba Instant and TACACS or TACACS+ support
    Posted May 18, 2019 12:48 AM
    Hi Victor,
    If you scroll down a little in the link you posted, you will find the following:
    As you can see, here it is said that TACACS server is the authentication server to authenticate and authorize all types of management users.
    It seems that says something different to what you pointed in your answer. The question is, which answer is the correct?, is TACACS or TACACS+?
    Regards
  • 4.  RE: Aruba Instant and TACACS or TACACS+ support
    Posted Jun 04, 2019 02:56 PM
    If TACACS+ is a Cisco proprietary protocol:
    https://ipwithease.com/tacacs-vs-tacacs/
    Why Aruba products implement TACACS+?
    It seems to be a contradiction.
    Anybody who can explain this?
    Regards
