last person joined: 2 hours ago
Aruba Instant - Bandwidth Allocation based on AD Account
  • 1.  Aruba Instant - Bandwidth Allocation based on AD Account
    Posted Jun 24, 2020 07:22 PM
    Hi All,
    We have Aruba Instant APs with Central.
    We would like to allocate bandwidth to the users based on the AD Accounts.
    Is this something we could achieve?
    Thanks.
  • 2.  RE: Aruba Instant - Bandwidth Allocation based on AD Account
    Posted Jun 24, 2020 08:52 PM
    What RADIUS server are you using?
  • 3.  RE: Aruba Instant - Bandwidth Allocation based on AD Account
    Posted Jun 24, 2020 08:55 PM
    I watched a video that it could be done with Aruba Clearpass.
    https://www.youtube.com/watch?v=BXa7zdbPU9c
    Could it be done with Microsoft NPS?
    Thanks.
  • 4.  RE: Aruba Instant - Bandwidth Allocation based on AD Account
    Posted Jun 24, 2020 09:01 PM
    Yes you can. Please refer to the following thread:
    https://community.arubanetworks.com/t5/Controllerless-Networks/IAP-single-SSID-different-roles-based-on-AD-OU-membership/td-p/303711
    In your roles, you can assign different BW limits.
    The link for VSA configuration:
    https://community.arubanetworks.com/t5/Controller-Based-WLANs/How-do-i-go-about-in-doing-Vlan-derivation-against-Microsoft/ta-p/184848
    You can use:
    Aruba-User-Role                 1      String   Aruba      14823
  • 5.  RE: Aruba Instant - Bandwidth Allocation based on AD Account
    Posted Jun 24, 2020 09:04 PM
    If you have an option, go for ClearPass. A neat solution and day to day monitoring/troubleshooting will be a lot easier.
  • 6.  RE: Aruba Instant - Bandwidth Allocation based on AD Account
    Posted Jun 24, 2020 09:06 PM
    Could you please share a document on how to install/configure Aruba Clearpass from scratch? and then link it to IAP on Central?
    Also, any configuration example for what we would like to achieve?
    Thanks.
  • 7.  RE: Aruba Instant - Bandwidth Allocation based on AD Account
    Posted Jun 24, 2020 09:14 PM
    Assuming you are installing it on a vmware  environment, you can refer to the following link:
    https://www.arubanetworks.com/techdocs/ClearPass/6.6/InstallingOnVM_6.6_TechNote/Content/InstallOnVM_6.6/ESXinstallations.htm
    Following links will be a good starting point for configuration:
    https://www.youtube.com/watch?v=-SPiKgoBsmI
    https://community.arubanetworks.com/t5/Security/How-to-map-access-to-a-specific-AD-Security-Group/td-p/309800
    I would recommend contacting the local Aruba partner. They should be able to help you with the POC or any configuration help you may need. Depending on your requirements, they should be able to help you with the right HW scaling and licensing information.
