Aruba instant Block all internet connection
  • 1.  Aruba instant Block all internet connection
    Posted Jul 13, 2016 02:40 PM
    Good Morning,
    i have installed 12 Aruba IAP 103RW, all work correctly and in the web interface i can see all 12 ap connected, but i can't go on internet.
    In my intranet all work correctly and from cable (cable connected to the same switch of the AP) internet work right, but when i connect to an ap i can see all pc in my intranet and i can ping all website but i can't
    navigate to it.
    AP firmware version is 6.4.2.0-4.1.1
    Any help would be appreciated.
    Thanks!
    Antonio
  • 2.  RE: Aruba instant Block all internet connection
    Posted Jul 13, 2016 09:52 PM
    Is your SSID using a virtual controller assigned VLAN (NAT) or a Network assigned VLAN (bridging it to a wired network)?
  • 3.  RE: Aruba instant Block all internet connection
    Posted Jul 14, 2016 01:55 AM
    My SSID is a Network assigned VLAN.
    Attached the configuration file.
    Attachment(s)
    txt
    instant.txt   3 KB 1 version
  • 4.  RE: Aruba instant Block all internet connection
    Posted Jul 14, 2016 02:00 AM
    What is the default gateway of your clients?
  • 5.  RE: Aruba instant Block all internet connection
    Posted Jul 14, 2016 04:44 AM
    The default gateway is a router with ip 10.0.0.1, the client recive the ip in DHCP from the router (the client ip is recived correctly).
    I have tried whit dns 8.8.8.8(google), 208.67.222.222(opendns) and provider DNS.
    The DHCP range is 10.0.0.50-10.0.0.250
    The AP have ip from 10.0.0.10 to 10.0.0.22
    From the client i can ping all website (google, amazon, apple, ecc.) but i can't navigate to it.
    Thank's
