Aruba Instant DHCP server max leases
  • 1.  Aruba Instant DHCP server max leases
    Posted Jun 17, 2013 06:00 AM
    How much leases can a Instant AP manage acting as a DHCP server?
    Thank you in advance
  • 2.  RE: Aruba Instant DHCP server max leases
    MVP EXPERT
    Posted Jun 17, 2013 06:27 AM
    The largest address pool supported is 2048. The default size of the IP address pool is 512
  • 3.  RE: Aruba Instant DHCP server max leases
    Posted Jun 17, 2013 06:30 AM
    I think i didn't explain very good.
    For example, for Aruba controller, it's not recommended more than 400 users using the internal DHCP server because the Aruba Controller DHCP server is not a primary process.
    Is there any recomendation like that for Instant AP?
  • 4.  RE: Aruba Instant DHCP server max leases
    MVP EXPERT
    Posted Jun 17, 2013 06:33 AM
    I checked the user guide (6.2.x) and I could not see any concerns. I expect it is the same as good practice guide to having around 200 clients per VLAN, however the default pool is 512. Maybe someone else can add to this?
