Aruba instant - disable SSID during night time
  • 1.  Aruba instant - disable SSID during night time
    Posted Dec 09, 2013 10:16 PM
    Using AirWave templates, it is possible to schedule two templates:
    One with no version restriction which applies during day time.
    One with version restriction which applies during night time.
    Doing this, it is possible to disable one/all SSID(s) during night time to prevent potential system abuse.
  • 2.  RE: Aruba instant - disable SSID during night time
    Posted Dec 10, 2013 10:05 PM
    Sorry for misleading some people...
    I actually did more extensive tests and the best way to do it is to actually move AP(s) and Virtual Controller(s) for the Day Time Group (with day time configuration template) to the Night Time Group (with the night time configuration template).
    This works without template version restrictions.
