Aruba Instant - IAP 215 - High utilization with very little use.
  • 1.  Aruba Instant - IAP 215 - High utilization with very little use.
    Posted Oct 04, 2019 04:44 AM
    Hi there,
    We have six access points that always seem to have high utilization (some APs sit at 89% with only 12 connected clients), we are in a large building with a number of interfering neighboring APs.
    We experience low download speeds across the WiFi (around 75% lower than ethernet connectivity), and I was wondering if it's because of the interference or maybe a few settings can be changed on the controller?
    I can divulge various AP controller settings if needed.
    Cheers
  • 2.  RE: Aruba Instant - IAP 215 - High utilization with very little use.
    Posted Oct 04, 2019 05:08 AM
    So is the high utilization with the IAP 215?
    Just to get a clearer idea,
    Are the six APs configured as APs or Instant Access Points?
    If APs(usually managed by a Mobility controller) which controller are you using and what is the image version?
    If IAPs what Instant OS version are you using?
    Are all the six devices facing the same issue or is it just one?
  • 3.  RE: Aruba Instant - IAP 215 - High utilization with very little use.
    Posted Oct 04, 2019 05:19 AM
    Hi Ajay
    Thanks for the reply!
    Thought it might be useful to chuck the configuration down to see if anything stands out as a 'no no'.
    version 6.4.2.0-4.1.1
    arm
    wide-bands 5ghz
    80mhz-support
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    client-match
    client-match calc-threshold 20
    client-match slb-mode 2
    rf dot11g-radio-profile
    interference-immunity 3
    rf dot11a-radio-profile
    wlan ssid-profile Main_Wifi
    enable
    index 0
    type employee
    essid Main_Wifi
    opmode wpa2-psk-aes
    max-authentication-failures 5
    auth-server InternalServer
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter arp
    blacklist
    dmo-channel-utilization-threshold 90
    local-probe-req-thresh 0
    All APs face the same issue, throughout the day they hit 85%+ utilisation across both 2.5 and 5.
    We have 200 devices across these APs :)
  • 4.  RE: Aruba Instant - IAP 215 - High utilization with very little use.
    Posted Oct 04, 2019 07:48 AM
    I see 80 MHz support is enabled and the airtime fairness mode is fair access.
    This usually means bandwidth is shared equally between all users irrespective of the requests they make or the order in which the requests are made.
    Is the 80MHz support necessary for your network and users?
    If it's not absolutely necessary, try disabling it during downtime if it's a production network.
