Aruba Instant IAP-305 (RW) setup in US
This thread has been viewed 21 times
  • 1.  Aruba Instant IAP-305 (RW) setup in US
    Posted Oct 07, 2021 01:27 PM
    Good day
    Hoping to get an answer as regards if the Aruba Instant IAP-305 (RW) can be used in our US office. We have 2 spares in our Canada office of the Aruba Instant IAP-305 (RW) that we want to use to expand WiFi coverage in the US office. I know these are labelled RW for Rest of the World just wondering if thgere any limitations with using them in the US.
    Kola Oladapo
    MB
  • 2.  RE: Aruba Instant IAP-305 (RW) setup in US
    Posted Oct 07, 2021 02:23 PM
    No, that will not work (unless you use them with a controller and convert them to controller-based APs).
    -RW Instant access points do not allow selection of the US country code, and they cannot join a US IAP cluster.
    This is to be compliant with FCC regulations (country selection flexibility is not allowed in the US).
    Onno Harms
  • 3.  RE: Aruba Instant IAP-305 (RW) setup in US
    Posted Oct 08, 2021 01:19 AM
    Thanks for your reply. I will go with ordering the below for the US office then.
    JX946A Aruba Instant IAP-305 (US) 802.11n/ac Dual 2x2:2/3x3:3 MU-MIMO Radio Integrated Antenna AP then.
    Kola Oladapo
    MB
  • 4.  RE: Aruba Instant IAP-305 (RW) setup in US
    MVP EXPERT
    Posted Oct 08, 2021 06:00 AM
    Correct, the (US) in the part name denotes it is for the US.
    Craig Syme
