Aruba Instant & IPv6
  • 1.  Aruba Instant & IPv6
    Posted May 24, 2012 06:38 PM
    I've got a small network of 3 Aruba IAP-105s (firmware 6.1.3.1-3.0.0.1_33617), serving two SSIDs on two VLANs -- using the untagged VLAN for management traffic.
    It seems that recently (possibly with a recent firmware upgrade) IPV6 router solicitation messages -- and it seems any IPv6 multicast traffic -- coming from wireless clients are not making it to the wired network. Clients on the wired network seem to do all right.
    I've got mutlicast "optimization" and broadcast filtering disabled on these SSIDs -- but I've tested with "optimization" on and still don't see the expected traffic.
    Are there any known limitations with the newer firmware versions, multicast, and IPv6 that I'm missing here? Swear this was working fine a couple of months ago!
    -rob
  • 2.  RE: Aruba Instant & IPv6
    Posted May 25, 2012 11:14 AM
    Can you please tell me what the last 'working' image you had on the IAPs for this to work?
    thanks,
    Shashi
  • 3.  RE: Aruba Instant & IPv6
    Posted May 25, 2012 12:25 PM
    This was certainly working when I was running the the 6.1.2.3-2.0.0.0 series code.
    If its any help, I've got mostly OSX & FreeBSD on the network, and a NetGear GS724TP switch. I only became aware of this situation when I couldn't access any of my AirPlay devices that were wireless-connected -- Apple would like to use IPv6 multicast for discovery if the client has an active IPv6 stack. (the temporary solution has been to completely disable the ipv6 stack on the client to force it to use ipv4)
    If you have a URL for the previous (6.1.2.3-2.0.0.0) firmware, I could try to downgrade the wireless firmware and verify the previous functionality.
    Thanks!
  • 4.  RE: Aruba Instant & IPv6
    Posted May 25, 2012 12:36 PM
    Do you have an account on the Aruba support site? All images are posted there including Instant 2.0.
    Drop me a note if you encounter any issues.
    I am checking with my engineering team to see if there could be anything that could break this - but we may not have tested for this use case internally.
    thanks,
    Shashi
    ssastry@arubanetworks.com
  • 5.  RE: Aruba Instant & IPv6
    Posted May 25, 2012 03:45 PM
    I did a quick test using IAP image version 6.1.3.1-3.0.0.1_33617 and did a packet capture. I see both ipv6 and ipv4 queries and responses with an iPad and apple tv.
    So, this is working even with the latest Instant code.
    thanks,
    Shashi
  • 6.  RE: Aruba Instant & IPv6
    Posted May 25, 2012 05:39 PM
    Thanks for testing. I may a factory reset on my switch and IAPs to see if some bad setting snuck in somewhere. Will follow up and let you know the results.
  • 7.  RE: Aruba Instant & IPv6
    Posted May 28, 2012 02:32 AM
    It seems that downgrading to 6.1.2.3-2.0.0.4_32946 does actually fix this problem. Since I don't need any 6.1.3.1 features right now, this isn't a big deal.
    To be more specific, the traffic that isn't making it onto the wireless network (or between wireless hosts) in 6.1.3.1 is the IPv6 multicast traffic (ethernet 33:33:xx:xx:xx:xx).
    Redacted configuration:
    version 6.1.2.0-2.0.0
    virtual-controller-country US
    virtual-controller-key XXX
    name nofocus
    virtual-controller-ip 192.168.4.6
    syslog-server 192.168.4.1
    terminal-access
    ntp-server 192.168.4.1
    clock timezone Pacific-Time -08 00
    rf-band all
    allow-new-aps
    allowed-ap XXX
    allowed-ap YYY
    allowed-ap ZZZ
    arm
    wide-bands 5ghz
    a-channels 36+,44+,149+,157+
    g-channels 1,6,11
    min-tx-power 18
    max-tx-power 127
    band-steering-mode prefer-5ghz
    air-time-fairness-mode fair-access
    client-aware
    scanning
    syslog-level warn ap-debug
    syslog-level warn network
    syslog-level warn security
    syslog-level warn system
    syslog-level warn user
    syslog-level warn user-debug
    syslog-level warn wireless
    mgmt-user admin XXX
    wlan ssid-profile FreePublicWifi
    index 0
    type employee
    essid FreePublicWifi
    wpa-passphrase XXX
    opmode wpa2-psk-aes
    vlan 103
    rf-band all
    captive-portal disable
    dtim-period 1
    inactivity-timeout 1000
    broadcast-filter none
    wlan ssid-profile CostlyPublicWifi
    index 1
    type employee
    essid CostlyPublicWifi
    opmode opensystem
    vlan 102
    rf-band 2.4
    dtim-period 1
    enet-vlan guest
    wlan access-rule default_dev_rule
    index 0
    rule any any match any any any deny
    wlan access-rule FreePublicWifi
    index 1
    rule any any match any any any permit
    wlan access-rule CostlyPublicWifi
    index 2
    wlan external-captive-portal
    server localhost
    port 80
    url "/"
    auth-text "Authenticated"
    ids classification
    ids
    wireless-containment none
  • 8.  RE: Aruba Instant & IPv6
    Posted May 29, 2012 02:22 PM
    Can you please send me a topology diagram with some idea of you IP addresses?
    client -> IAP -> switch/router -> IAP -> client <something like this?>
    and what is failing.
    thanks,
    Shashi (ssastry@arubanetworks.com)
  • 9.  RE: Aruba Instant & IPv6
    Posted Jun 29, 2012 10:26 PM
    Thanks robertbanz for posting your note.  I too was having issues with 6.1.3.1 when reattaching Windows 7 computers to my homegroup.  Had to hardwire the laptops to rejoin the group.  I was then able to print over WiFi.
    I just down graded the Instant to 6.1.2.3 and was able to rejoin my homegroup successfully.
    Thanks.
  • 10.  RE: Aruba Instant & IPv6
    Posted Oct 08, 2012 02:32 AM
    I can report that IPv6 still does not work in 6.1.3.4-3.1.0.0_35320.
    Is IPv6 on Instant tested by Aruba before each software release? It is late 2012 and IPv6 should, IMHO, be considered a critical feature that can not be ignored for several versions. And I know that Aruba has been aware of this problem for several months now.
    It would be great if we can get an offical response from Aruba on this.
  • 11.  RE: Aruba Instant & IPv6
    Posted Oct 08, 2012 06:52 AM
    jschlyter,
    Have you reported an issue?  What IPv6 feature is not working?
  • 12.  RE: Aruba Instant & IPv6
    Posted Oct 10, 2012 05:31 AM
    Yes, I have reported this issue to my local Support Engineer.
    IPv6 multicast does not work; hence not much works at all. This also impacts Apple Airplay, which uses IPv6 link-local.
        jakob
  • 13.  RE: Aruba Instant & IPv6
    Posted Oct 09, 2012 12:32 PM
    Passthrough of IPv6 traffic from clients will be supported in the next release of the Instant software. i.e 3.2
    Michael
  • 14.  RE: Aruba Instant & IPv6
    Posted Oct 10, 2012 05:27 AM
    Any ETA for 3.2?
        jakob
