Aruba Instant LACP configuration
  • 1.  Aruba Instant LACP configuration
    Posted Jul 13, 2018 11:56 AM
    Is there any documentation for configuring LACP in an Aruba Instant environment? Most of what I've found relates to Aruba OS.
    I have an IAP-325 that I would like to use both ethernet ports for increased throughput. It is connected to an Aruba/HP 2920-48G-POE+ Switch. The wifi traffic is vlaned, all on the same subnet.
    I ran the LACP -enable on the AP, however, I 'm not sure what else needs to be configured on the master AP in the cluster and or switch.
  • 2.  RE: Aruba Instant LACP configuration
  • 3.  RE: Aruba Instant LACP configuration
    Posted Aug 29, 2018 03:54 AM
    What is the best practise process of applying  LACP on IAP 325 in aruba central.
    I currently configured my switch with command
    trunk 3,4 trk1 lacp
    and linked my IAP to it, am I missing any command to back it up?
  • 4.  RE: Aruba Instant LACP configuration
    Posted Aug 29, 2018 04:59 AM
    Is striping IP required for IAP running in aruba central?
  • 5.  RE: Aruba Instant LACP configuration
    Posted Aug 29, 2018 05:39 AM
    It is not.
  • 6.  RE: Aruba Instant LACP configuration
    Posted Aug 29, 2018 05:45 AM
    What about the best practise to setup an LACP port on a switch for IAP?
