last person joined: 8 hours ago
Aruba Instant - MPSK + ClearPass
This thread has been viewed 19 times
  • 1.  Aruba Instant - MPSK + ClearPass
    Posted Jan 25, 2022 09:16 AM
    Hello all,
    From what ?I have read MPSK is supported with Instant and ClearPass. My question is what are the limitations, Will the MPSK only work on a single VC / AP cluster or will it work between cluster. This is for a University, halls of residence environment with multiple VC's.
    Jason
  • 2.  RE: Aruba Instant - MPSK + ClearPass
    MVP GURU
    Posted Jan 25, 2022 09:48 AM
    You will need to configure your MPSKs on each VC (each Instant Cluster) if you are using MPSK-Local. You are also limited to 24 PSKs per cluster.
    If you use MPSK-AES with ClearPass you do not run into that limitation, and you can have one central location for all of your IAP clusters to authenticate against. No having to manually configure them across VCs.
    Dustin Burns
    ACCX 1271| ACMX 509| ACSP | ACDA | MVP Guru 2022
