Aruba Instant - Multiple external Captive portal URLs
  • 1.  Aruba Instant - Multiple external Captive portal URLs
    Posted Sep 12, 2013 12:56 PM
    I am using Aruba Instant and External captive portal authentication (Clearpass).
    I am trying to set up 2 different SSIDs, each with their own captive portal URL.
    It seems this is not possible. Whatever values I input for 1 SSID are copied to the other SSID.
    Does anyone know if there is a workaround, or any plans from Aruba to fix this?
  • 2.  RE: Aruba Instant - Multiple external Captive portal URLs
    Posted Sep 12, 2013 01:10 PM
    This is a roadmap item.  Not sure about any timelines right now.  As of now with Instant only, you can have only 1 Captive portal profile.  With ClearPass Guest, we can work some magic to fix this.
  • 3.  RE: Aruba Instant - Multiple external Captive portal URLs
  • 4.  RE: Aruba Instant - Multiple external Captive portal URLs
    Posted Sep 12, 2013 02:05 PM
    Fantasitc, Seth.
    Many thanks. Works perfectly.
