Aruba Instant + NPS server authentication issues (Event ID 18)
  • 1.  Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 05:32 PM
    Hello everyone !
    I'm currently stuck on some weird issues. NPS server's event viewer sends a lot of those error messages (Event ID 18).
    I tried multiple times to re-enter the shared secret on both the NPS Client and Instant AP RADIUS Server info. When I re-enter the secret, the authentications work for some time and then they stop working and results in this error again.
    When I look into Wireshark, I see Acces-Request from IAP to NPS and Access-Challenge from NPS to IAP. I don't see any Access-Accept or Access-Reject. I guess the IAP doesn't receive it.
    I also tried re-creating radius server and upgrading firmware to latest General Avaibality (6.4.2.6 4.1.1.12)
    Thanks !
  • 2.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 05:35 PM
    Double check the radius secret.
  • 3.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 05:36 PM
    Can you try using a very simple shared key?
    Something like "aruba123"
    Sent from Outlook for iPhone
  • 4.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 05:45 PM
    Thanks for the quick answer guys.
    I must have re-entered it 4-5 times, my key is Test123! and I even verified keyboard language on NPS server. Still, if I enter it again, it works for some time.
    I'm also using Radius Proxy on VC ip adress.
    Thanks !
  • 5.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 05:59 PM
    For testing purposes can you try just test123 and see if it works
  • 6.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 06:06 PM
    Alright, i'll try this tomorrow morning and update you !
  • 7.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 06:25 PM
    Actually on NPS there is an option to verify the message authenticator attribute. Uncheck that.
  • 8.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 17, 2016 07:59 PM
    Ok thx ill get back to you guys tomorrow morning !!
  • 9.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 18, 2016 11:43 AM
    ok so :
    1. secret is now aruba123
    2. dynamic radius proxy is off and i manually added the IAPs in NPS server
    3. Message authenticator attribute was deactivated
    Same problem persist. There is 3 sites, 1 of them is with IAP-225 and Cisco switch, everything works well and all authentications to the same NPS server are ok.
    2 other sites are with IAP-215 and Juniper EX4200, no FW and have both the same issues.
    I'm starting to think this is a Juniper feature/firmware issue or IAP-215 interoporability problem.
    Thoughts ?
  • 10.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 20, 2016 10:33 PM
    Can you run the following command and share the output:
    IAP-2# show ap debug auth-trace-buf
  • 11.  RE: Aruba Instant + NPS server authentication issues (Event ID 18)
    Posted Mar 21, 2016 06:31 PM
    only way I was able to solve this problem is with a factory reset on both IAP-215 clusters (2 separate VCs).
    Sorry, I don't have outpute since iv'e read this too late.
