Aruba Instant On AP22 - Functions
  • 1.  Aruba Instant On AP22 - Functions
    Posted Jan 18, 2022 12:58 PM
    Which Aruba AP Model supports these Functions? Aruba Instant On AP22 or do i need a higher end Model?
    • 802.11 standards - a - b - g - n (WiFi 4) - ac (WiFi 5) - ax (WiFi 6)• Frequencies and range - 2.4GHz - 5GHz• Channels - Regulatory impacts• Channel bonding• Service set identifier (SSID) - Basic service set - Extended service set - Independent basic service set (Ad-hoc) - Roaming• Antenna types - Omni - Directional• Encryption standards - WiFi Protected Access (WPA)/  WPA2 Personal [Advanced   Encryption Standard (AES)/  Temporal Key Integrity Protocol (TKIP)] - WPA/WPA2 Enterprise (AES/TKIP) • Multiple input, multiple output (MIMO)  and multi-user MIMO (MU-MIMO)
    Best Regards
    David Koller
  • 2.  RE: Aruba Instant On AP22 - Functions
    Posted Jan 19, 2022 10:07 AM
    Please check the Aruba InstantON website and the dedicated Aruba InstantON community for these types of questions.
    AP22 is WiFi-6 and the other requirements seem to be matched as well.
    Note that InstantON is a separate product line for small and medium businesses, and should not be mixed with Aruba controller or Aruba Instant WiFi.
  • 3.  RE: Aruba Instant On AP22 - Functions
    Posted Jan 19, 2022 10:19 AM
    Thanks for your Answer.
    Do you know if the AP-505 supports all listed Features?
    Best Regards
    David Koller
  • 4.  RE: Aruba Instant On AP22 - Functions
    Posted Jan 19, 2022 04:54 PM
    yes AP-505 supports those functionalities
    here is the link to AP-505's datasheet
    https://www.arubanetworks.com/resource/aruba-500-series-wireless-access-points-data-sheet/
  • 5.  RE: Aruba Instant On AP22 - Functions
    Posted Jan 19, 2022 05:37 PM
    David Koller
