Aruba Instant Upgrade with URL
This thread has been viewed 42 times
  • 1.  Aruba Instant Upgrade with URL
    Posted May 11, 2017 07:55 AM
    Hi all,
    I am about to upgrade an aruba instant implementation consisting of Aruba 205 and 275 APs. By going to Maintenance -> Firmware tab the only available option is to use manual URL option. I observed that in our office where we have only Aruba 205 APs there is one more option available in order to insert the image file. Does anyone know why is this happening ?
    Moreover I would like to ask you if there is any available aruba http server so as to directly put the appropriate url links on the fields.
    Thanks in advance
  • 2.  RE: Aruba Instant Upgrade with URL
    Posted May 15, 2017 01:50 AM
    Only optionin cluster is need to manually past the URL of individula model firmware codes to ugprade the cluster.
    Pavan
  • 3.  RE: Aruba Instant Upgrade with URL
    Posted May 15, 2017 07:58 AM
    @Angus13 wrote:
    Hi all,
    Thanks in advance
    Browse to file is only available where a cluster only has a single class of APs.  With two or more classes of APs in a cluster, you have to setup a tftp, ftp or http server to upgrade the cluster:  http://www.arubanetworks.com/techdocs/Instant_423_WebHelp/InstantWebHelp.htm#UG_files/IAP_maintenance/Firmware_Image_Server_in.htm?Highlight=upgrade
