Aruba Instant with Clearpass Captive Portal Source IP / NAT
  • 1.  Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 10, 2014 06:04 AM
    I am going to configure some Locations with Aruba Instant an have a centralized Clearpass Server,
    how do i get the clients to communicate with the Clearpass Logon Site? Is it possible to NAT the Clients, that the virtuell controller IP is used to communicate with the clearpass server?
    And can the virtual controller NAT the Clients to an public IP after they are authorized from Clearpass?
  • 2.  RE: Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 10, 2014 07:37 AM
    Once the user has register through the captive portal then you can return a role that source NAT the traffic
  • 3.  RE: Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 19, 2014 08:45 AM
    It's more about the login on the clearpass. I like to masquerade the guest behind the virtuall controller ip because there I no route from the clearpass to the guest ip range
  • 4.  RE: Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 21, 2014 08:22 AM
    The setup is a network assignt vlan for guest with no routing to the internal networks. DHCP and dns from the network. The iap is not the default gateway.
    The clearpass server is in the internal networks
    What acl has to be in the the pre authentication rule to get a connection to the clearpass server?
    Source nat http and https to destination clearpass server
    + allow DHCP + dns?
    Or is the captive portal rule needed with pre-configured cp profile?
  • 5.  RE: Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 23, 2014 04:00 AM
    + allow DHCP + dns worked, but the automatik redirect does not work.
    any suggestions?!
  • 6.  RE: Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 23, 2014 04:24 AM
    Can you elaborate on "automatic redirect" does not work? Is it the redirect after login?
    Sent from my iPhone
  • 7.  RE: Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 23, 2014 04:54 AM
    no it is the redirect to the clearpath login page.
    I connect to the SSID, get an IP Adress and DNS is working. When i open a firefox and type a website i only get an error message and no redirect to the logon page.
    I added a source Nat rule and can login when i use the 172.16.1.10/guest/guest_logon.php url. But the redirect does not work
    running 6.4.2 on IAP 108
    here is my captive Portal profile and the pre-auth role/acl
    wlan external-captive-portal CP
     server 172.16.1.10
     port 443
     url "172.16.1.10/guest/guest_logon.php"
     auth-text ""
     auto-whitelist-disable
     https
    wlan access-rule Guest-Logon
     index 4
     captive-portal external profile CP
     rule 172.16.1.10 255.255.255.255 match any any any src-nat
     rule any any match udp 67 68 permit
     rule any any match udp 53 53 permit
     rule 172.16.1.10 255.255.255.255 match tcp 80 80 permit
     rule 172.16.1.10 255.255.255.255 match tcp 443 443 permit
  • 8.  RE: Aruba Instant with Clearpass Captive Portal Source IP / NAT
    Posted Oct 23, 2014 05:43 AM
    found the solution here in the forum :)
    http://www.airheads.eu/t5/Aruba-Instant-Cloud-Wi-Fi/Instant-does-not-redirect-to-Clearpass/td-p/200527
    it is the captive portal profile
     server 172.16.1.10
     port 443
     auth-text ""
     https
    has to be
     server 172.16.1.10
     port 443
     url "/guest/guest_logon.php"
     auth-text ""
     https
