Wired Intelligent Edge
Aruba InstantON 1930 (HPE-JL680A) problem with SFP
This thread has been viewed 30 times
  • 1.  Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 26, 2021 12:22 AM
    Hello guys,
    I'm having a problem with fiber optic connection to the mentioned switch. I have the following configuration:
    TP-Link MC220L Gigabit SFP Media converter
    SFP Module inside media converter is TL-SM311LS 1000Base-LX
    SFP Module inside switch is MaxLink ML-S31D-3-HP
    Problem is that switch does not see the link, when i connect fiber optic to switch, led blinks for a second and that's it, link is down.
    Switch FW version is 1.0.5.0(139)
    #Port
    #Aruba
  • 2.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 26, 2021 04:47 AM
    Hello @hpe091,
    Was this working earlier or its a new issue?
    Are you using HPE branded SFP?
    Please refer below links for supported SFP's on this switch:
    https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=a00101702en_us
    https://support.hpe.com/hpesc/public/docDisplay?docLocale=en_US&docId=a00101703en_us
    Thanks!
  • 3.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 26, 2021 09:45 AM
    @akg7
    Thank you for Your response.
    Switch is new, and our seller checked with the supplier and offered us 2 maxlink SFP modules and they said that that module is compatible with this switch. The MaxLink ones in my original post.
  • 4.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 26, 2021 05:19 PM
    Hello @hpe091 ,
    We request you to log a case on HPE Support Center portal for further resolution using the link:
    https://support.hpe.com/hpesc/public/home/
    Thanks!
  • 5.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 27, 2021 05:21 AM
    Little update,
    I connected my new aruba switch with an old Procurve switch 2626 and then link works without a problem. Why doesn't work with my media converter ?
  • 6.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 27, 2021 05:54 AM
    Hello @hpe091 ,
    What log messages have you seen  when conencted fiber optic?
    Can you again connect fiber optic to switch again check and share logs?
    Thanks!
  • 7.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 27, 2021 06:15 AM
    This is when I connect two switches. I insert SFP module into port 10 on aruba switch:
    1 Oct 27 2021 12:03:41 Notice NT_LLDP-N-LLDP_TRAP LLDP status: entry deleted on 10.
    2 Oct 27 2021 12:03:41 Info LINK-I-Up Vlan 30
    3 Oct 27 2021 12:03:41 Info LINK-I-Up Vlan 20
    4 Oct 27 2021 12:03:41 Info LINK-I-Up 10
    5 Oct 27 2021 12:03:38 Info NSFP-I-SFPGibicDetected 10 SFP port is present, module type - 1000BASE-LX
    This is when i connect switch to media converter:
    1 Oct 27 2021 12:04:16 Info NSFP-I-SFPGibicDetected 10 SFP port is present, module type - 1000BASE-LX
  • 8.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 28, 2021 05:29 AM
    Hello @hpe091 ,
    Below meesage shows that SFPGibic Detected:
    After this anyother message seen?
    What is the status of this module in switch?
    Thanks!
  • 9.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 28, 2021 05:51 AM
    No, that's it, when connecting to media converter that's the only message that is seen. Switch says link down.
  • 10.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 28, 2021 04:47 PM
    Hello @hpe091 ,
    It seems there is a compatibility issue between media convertor and SFP..
    There might be remote intervention required.
    Can you log a case with support  if they can assist on this issue?
    Thanks!
  • 11.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Oct 29, 2021 12:05 AM
    I can't, when i want to make a case, webpage can't find my switch. I tried serial number and everything but it can't find the switch.
  • 12.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Nov 27, 2023 04:56 PM
    Hi, has anyone managed to solve the problem with connecting to TPLink?
  • 13.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    Posted Nov 28, 2023 02:21 AM
    I will answer myself :). After installing the latest firmware from November 2.9.0.53 - Aruba started working with TPLink.
  • 14.  RE: Aruba InstantON 1930 (HPE-JL680A) problem with SFP
    MVP EXPERT
    Posted Nov 28, 2023 05:08 PM
    Good to hear you solve the issue.  Note that Aruba InstantON have its own community https://community.arubainstanton.com/home
    Marcel Koedijk | MVP Expert 2023 | ACEP | ACMP | ACCP | ACDP | Ekahau ECSE | Not an HPE Employee | Opinions are my own
