Aruba Internal database use
  • 1.  Aruba Internal database use
    Posted Aug 19, 2015 08:44 PM
    I have Aruba IAP cluster and Aruba controller based APs in the same network. I have hundreds of internal database users created in my Aruba controller (3200). Can I authenticate internal database users via IAP cluster? any solution. Or else Can I use controller internal database to act as a RADIUS or LDAP server?
  • 2.  RE: Aruba Internal database use
    Posted Aug 19, 2015 08:45 PM
    No to both. You need an external server to authebticate both from the same place, unfortunately.
  • 3.  RE: Aruba Internal database use
    No this is not possible. You should stand up a RADIUS server.
