Community Feedback
How is the community doing? Do you have any questions or feedback related for the Airheads Community team? This is the place to let us know.
Aruba J9772A 2530 48G -Port
  • 1.  Aruba J9772A 2530 48G -Port
    Posted Jul 11, 2022 09:36 PM
    Good afternoon I have a problem where the ports are offline and then return to online causing the network to be oscillating. Does anyone know a solution to this problem?
  • 2.  RE: Aruba J9772A 2530 48G -Port
    MVP GURU
    Posted Jul 12, 2022 07:24 AM
    Hi, you need to discover the offending ports. Is there any physical loop in your network? a loop (or more loops) will cause network storm(s) if the STP (Spanning Tree) was not configured properly to kick in at the right time against the offending loops to protect your network.
    Please properly check your network, each connection and report back.
