Wired Intelligent Edge
Aruba JL253A 2930F-24G-4SFP+ issue/bug
  • 1.  Aruba JL253A 2930F-24G-4SFP+ issue/bug
    Posted Jun 06, 2019 02:13 AM
    I have 2 Aruba JL253A 2930F-24G-4SFP+ connected as a stack.
    Today I have experienced a very ugly issue.
    I wanted to connect to the core via SSH to checkout the config.
    I connected to the core switch but one member of the core stuck somehow, the fans of the switch were at maximum. The leds of the ports were not lit. Only the leds from the right of switch were lit.
    When I connected directly to the port of switch the eth interface was not raised.
    In order to restore the functionality I had to take the power out.
    Did you guys read about this...had this type of events?
    what can be done.
    This is my FW version : Version WC.16.06.0006
    Here is the log from it.
    I 06/05/19 11:07:16 04908 ntp: ST1-CMDR: The system clock time was changed by 0
                sec 117265045 nsec.  The new time is Wed Jun  5 11:07:17 2019
    I 06/05/19 11:07:16 04910 ntp: ST1-CMDR: All the NTP server associations reset.
    I 06/05/19 11:09:46 04911 ntp: ST1-CMDR: The NTP Server 151.101.2.217 is
                unreachable.
    I 06/05/19 11:10:23 00288 addrMgr: ST1-CMDR: Frame received on port 1/18 from
                MAC address 000000-000000.
    I 06/05/19 11:18:51 00179 mgr: ST1-CMDR: SME SSH from x.x.x.x - MANAGER Mode
    I 06/05/19 11:20:00 03262 stacking: ST2-STBY: Member failed because
                synchronization failed
    W 06/05/19 11:20:00 03257 stacking: ST1-CMDR: Reboot of d09999-e47f80 Successful
    I 06/05/19 11:20:00 03272 stacking: ST1-CMDR: Stack fragment active
    I 06/05/19 11:20:00 03271 stacking: ST1-CMDR: Topology is a Standalone
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/1 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/2 in Trk2 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/3 in Trk3 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/4 in Trk4 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/5 in Trk5 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/7 in Trk7 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/14 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/16 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/18 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/22 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/23 is now off-line
    I 06/05/19 11:20:00 00077 ports: ST1-CMDR: port 2/24 is now off-line
    I 06/05/19 11:20:00 00002 vlan: ST1-CMDR: ISP2 virtual LAN disabled
    I 06/05/19 11:20:03 04992 vsf: ST1-CMDR: VSF port 1/27 is in error state
    I 06/05/19 11:20:03 04992 vsf: ST1-CMDR: VSF port 1/28 is in error state
    I 06/05/19 11:20:03 04992 vsf: ST1-CMDR: VSF link 1 is down
    I 06/05/19 11:20:04 00842 stp: ST1-CMDR: CIST starved for a BPDU Rx on port Trk2
                from 32768:788888-fd69d2
    I 06/05/19 11:20:04 00839 stp: ST1-CMDR: CST Root changed from 32768:
                78888-fd69d2 to 32768: (this device)
    I 06/05/19 11:20:04 00435 ports: ST1-CMDR: port 1/2 is Blocked by STP
    I 06/05/19 11:20:04 00839 stp: ST1-CMDR: CST Root changed from 32768: (this
                device) to 32768: b4fbe4-238b40
    I 06/05/19 11:20:06 00839 stp: ST1-CMDR: CST Root changed from 32768:
                b4fbe4-238b40 to 32768: 78888-fd69d2
    I 06/05/19 11:20:06 00435 ports: ST1-CMDR: port 1/6 is Blocked by STP
    I 06/05/19 11:20:06 00076 ports: ST1-CMDR: port 1/2 in Trk2 is now on-line
    I 06/05/19 11:20:06 00076 ports: ST1-CMDR: port 1/6 in Trk6 is now on-line
    I 06/05/19 11:20:15 04992 vsf: ST1-CMDR: VSF port 1/27 is down
    I 06/05/19 11:20:15 04992 vsf: ST1-CMDR: VSF port 1/28 is dow
  • 2.  RE: Aruba JL253A 2930F-24G-4SFP+ issue/bug
    MVP GURU
    Posted Jun 06, 2019 02:23 AM
    Hi, can you share the running configuration. At first sight it looks like your VSF suffered a VSF split.
    It's reported here:
    I 06/05/19 11:20:00 03262 stacking: ST2-STBY: Member failed because synchronization failed
  • 3.  RE: Aruba JL253A 2930F-24G-4SFP+ issue/bug
    Posted Jun 06, 2019 02:55 AM
    CORESTACK01# show running-config
    Running configuration:
    ; hpStack_WC Configuration Editor; Created on release #WC.16.06.0006
    ; Ver #13:4f.f8.1c.9b.3f.bf.bb.ef.7c.59.fc.6b.fb.9f.fc.ff.ff.37.ef:05
    hostname "CORESTACK01"
    vsf
    enable domain 777
    member 1
    type "JL253A" mac-address d06726-e4fe00
    priority 200
    link 1 1/26-1/28
    link 1 name "I-Link1_1"
    link 2 name "I-Link1_2"
    exit
    member 2
    type "JL253A" mac-address d06726-e47f80
    priority 100
    link 1 2/27-2/28
    link 1 name "I-Link2_1"
    link 2 name "I-Link2_2"
    exit
    member 3
    type "JL253A"
    priority 128
    link 1 name "I-Link3_1"
    link 2 name "I-Link3_2"
    exit
    port-speed 10g
    exit
    trunk 1/2,2/2 trk2 lacp
    trunk 1/3,2/3 trk3 lacp
    trunk 1/4,2/4 trk4 lacp
    trunk 1/5,2/5,2/17 trk5 lacp
    trunk 1/6,2/6 trk6 lacp
    trunk 1/7,2/7 trk7 lacp
    timesync ntp
    ntp unicast
    ntp server 93.190.144.3 iburst
    ntp server 151.101.2.217 iburst
    ntp enable
    ip default-gateway 10.8.50.1
    snmp-server community "public" unrestricted
    vlan 1
    name "VLAN50 ADMIN"
    no untagged 1/8-1/16,1/18-1/24,2/8-2/14,2/16,2/18,2/22-2/24
    untagged 1/1,1/17,1/25,2/1,2/15,2/19-2/21,2/25-2/26,3/1-3/28,Trk2-Trk7
    ip address 10.8.50.10 255.255.255.0
    ipv6 enable
    ipv6 address dhcp full
    exit
    vlan 10
    name "Office WiFi"
    tagged 1/1,1/15,1/17,2/1,Trk2,Trk5
    no ip address
    exit
    vlan 11
    name "Guests WiFi"
    tagged 1/1,2/1,Trk2
    no ip address
    exit
    vlan 15
    name "Academy"
    tagged 1/1,1/17,2/1,Trk2,Trk5
    no ip address
    exit
    vlan 30
    name "Support"
    untagged 1/13-1/16,1/18-1/19,2/13-2/14,2/16,2/18
    tagged 1/1,2/1
    no ip address
    exit
    vlan 40
    name "DUI"
    tagged 1/1,2/1,Trk2-Trk5,Trk7
    no ip address
    exit
    vlan 41
    name "AV"
    untagged 1/8-1/12,2/8-2/12
    tagged 1/1,2/1,Trk5,Trk7
    no ip address
    exit
    vlan 60
    name "Security"
    tagged 1/1,2/1,Trk6
    no ip address
    exit
    vlan 100
    name "ISP1"
    untagged 1/22-1/24
    no ip address
    exit
    vlan 150
    name "ISP1_2"
    untagged 1/20-1/21
    no ip address
    exit
    vlan 200
    name "ISP2"
    untagged 2/22-2/24
    no ip address
    exit
    spanning-tree
    spanning-tree Trk2 priority 4
    spanning-tree Trk3 priority 4
    spanning-tree Trk4 priority 4
    spanning-tree Trk5 priority 4
    spanning-tree Trk6 priority 4
    spanning-tree Trk7 priority 4
  • 4.  RE: Aruba JL253A 2930F-24G-4SFP+ issue/bug
    MVP GURU
    Posted Jun 06, 2019 04:06 AM
    Is it correct that VSF context shows an asymmetrical number of ports member of VSF Link 1 (1/26 to 1/28, 3 interfaces versus 2/27 to 2/28, 2 interfaces) and a reference to a 3rd VSF Member with a VSF Priority of 128?
    Have you followed best practices/guide to deploy this VSF correctly?
    vsf
    enable domain 777
    member 1
    priority 200
    link 1 1/26-1/28
    exit
    member 2
    priority 100
    link 1 2/27-2/28
    exit
    member 3
    type "JL253A"
    priority 128
    exit
    port-speed 10g
    exit
    I also strongly suggest you to use the latest WC.16.06.0011 instead of the oldest WC.16.06.0006.
  • 5.  RE: Aruba JL253A 2930F-24G-4SFP+ issue/bug
    Posted Jun 06, 2019 06:39 AM
    Well the thing is that I found the structure like this. My issue is that this site is live 24h a day and I cannot set them up when I want or test when nobody is here...
    The thing is that I have 3 members but I don't think they are setup correctly because on the web interface I can see only two members.
    The sw1 and sw2 are connected with 2 SFP cables ports and the third member is connecte only with one SFP cable from SW1.
    Regarding the FW upgrade I have some questions ...If I make the upgrade do I loose the config ?
    Can I update directly from my version of firmware to the latest ?
  • 6.  RE: Aruba JL253A 2930F-24G-4SFP+ issue/bug
    Posted Jun 06, 2019 12:20 PM
    You won't lose the config if you have it saved.  However, the stack will go down for 2-3 minutes while the stack members reboot.
    You can upgrade directly to the new firmware without any issues.
