Wired Intelligent Edge
Aruba JL479A 8320 switch Syslog configuration CLI commands
This thread has been viewed 26 times
  • 1.  Aruba JL479A 8320 switch Syslog configuration CLI commands
    Posted Nov 30, 2021 01:04 PM
    Hi All i am facing some issue with my switch configuration its an Aruba JL479A 8320 switch and i have configured syslog on it but its not working please someone send me the correct configuration commands.
    I used these commands for syslog configuration:
    logging 172.27.48.116 severity debug
    sanjib behera
  • 2.  RE: Aruba JL479A 8320 switch Syslog configuration CLI commands
    Posted Nov 30, 2021 05:01 PM
    perhaps you have to configure "ip source-interface" for syslog and the correct VRF.
    switch(config)# ip source-interface syslog 172.27.48.116  vrf <vrf-name>
  • 3.  RE: Aruba JL479A 8320 switch Syslog configuration CLI commands
    Posted Nov 30, 2021 11:47 PM
    I have all my vlans under default VRF
    so this command will work for it .
    sanjib behera
  • 4.  RE: Aruba JL479A 8320 switch Syslog configuration CLI commands
    Posted Dec 01, 2021 12:51 AM
    so if you only have one VRF by multiple VLANs and if the switch has IP address in all these VLANs then for predictability you can use
    ip source-interface all interface vlan20 (as an example)
  • 5.  RE: Aruba JL479A 8320 switch Syslog configuration CLI commands
    Posted Dec 01, 2021 01:52 AM
    Hi Sanjib!
    Can you reach 172.27.48.116 from the 8320? Did you try to ping it from the switch interface?
    What s/w version 8320 is running?
    Ivan Bondar
  • 6.  RE: Aruba JL479A 8320 switch Syslog configuration CLI commands
    Posted Dec 01, 2021 04:40 AM
    Yes it is reachable to the syslog server.
    And 8320 is running with S/w TL.10.03.0071.
    sanjib behera
