Wired Intelligent Edge
Aruba LACP algorithm recommendation
  • 1.  Aruba LACP algorithm recommendation
    Posted Jun 27, 2016 09:39 PM
    What is the recommended LACP load balancing algorithm (from the switch perspective) for both Aruba Controllers and APs?
    I have enabled LACP and configured some APs, however I have taken a guess as to what algorithm to use.
    I am using Dell PowerConnect swiches, so I have the following options available:
    1 - Src MAC, VLAN, EtherType, Src module and portId.
    2 - Dest MAC, VLAN, EtherType, Src module and portId.
    3 - Src IP and Src TCP/UDP port.
    4 - Dest IP and dest TCP/UDP port.
    5 - Src/Dest MAC, VLAN, EtherType, Src MODID/port.
    6 - Src/Dest IP and Src/Dest TCP/UDP port.
    7 - Enhanced hashing mode.
    Currently I have the following algorithms set:
    Switch -> AP225 = 6 - Src/Dest IP and Src/Dest TCP/UDP port.
    Switch -> W-7210 = 6 - Src/Dest IP and Src/Dest TCP/UDP port.
  • 2.  RE: Aruba LACP algorithm recommendation
    Posted Jul 11, 2016 01:44 AM
    Does anyone know the LAG recommendations from Aruba?
