Aruba LDAP authentication
  • 1.  Aruba LDAP authentication
    Posted Nov 22, 2012 06:17 AM
    Hello,I try to link  Aruba Controller with LDAP Server(Windows2008) for authenticating Active Directory User.
    Configuring aaa-authentication-server as ldap, it shows " authentication failed" on executing "aaa query user" from console.
    When I see the result of "show aaa authentication-server statistics", all statistics shows 0.
    Considering those statistics, I'm afraid that there may be any wrong configurations.
    Can anyone show what gives wrong configuration ?
    I configure LDAP Server as follows:
    aaa authentication-server ldap "win2008"
       host 192.168.1.124
       admin-dn "administrator"
       admin-passwd 731e5a97ee42c61d372fdcf9f3bb9288886df767ef25a742
       base-dn "CN=Users,DC=test-domain,DC=com"
    aaa server-group "ldap"
     auth-server win2008
    aaa profile "ldap-test"
       authentication-dot1x "ldap-test"
       dot1x-server-group "ldap"
    When I execute a query command.
    (Aruba620) #aaa query-user win2008 Administrator
    Authentication failed
    When I execute a statistics command.
    (Aruba620) #show aaa authentication-server ldap statistics
    LDAP Server Statistics
    Statistics             win2008
    Login Requests         0
    Login Success          0
    Login Failure          0
    Login Timeout          0
    Total Unbind Requests  0
      - Reason: Timeout    0
    AvgRespTime (ms)       0
    Uptime (d:h:m)         0:0:0
    (Aruba620) #show ver
    ArubaOS (MODEL: Aruba620), Version 6.1.2.8
    Website: http://www.arubanetworks.com
    Copyright (c) 2002-2012, Aruba Networks, Inc.
    Compiled on 2012-02-24 at 23:49:46 PST (build 32519) by p4build
    ROM: System Bootstrap, Version CPBoot 1.0.0.0 (build 23274)
    Built: 2010-01-19 11:11:41
    Built by: p4build@re_client_23274
    Regards
  • 2.  RE: Aruba LDAP authentication
    Posted Nov 22, 2012 06:28 AM
    Try to double-check the password of the bind user (Administrator)
    AAA query user does not authenticate any user,... it just pulls LDAP attributes, so it will not increase the AAA statistics counters.  To test the user, you should use:
    aaa test-server pap win2008 (username) (password)
  • 3.  RE: Aruba LDAP authentication
    Posted Jul 13, 2015 08:07 AM
    Hi
    Customer is using IAP-93 and they want to convert as controller based ... also they goin to purchase new model AP's so wat type of controller can suggest ....
       host 192.168.1.124
     auth-server win2008
    Statistics             win2008
    Login Requests         0
    Login Success          0
    Login Failure          0
    Login Timeout          0
      - Reason: Timeout    0
    AvgRespTime (ms)       0
    Regards
    Mani Kandan
  • 4.  RE: Aruba LDAP authentication
    Posted Jul 13, 2015 08:11 AM
    As said above, please double check the username and password of the bind user, to make sure that is correct.  Please also double check the fqdn of the base-dn.
    Quite frankly, few people use ldap because on the ldap side there is little feedback about errors when they occur.  It is advised that the user deploy radius, instead for authentication, because it is more flexible and it has more straightforward support for encryption.
