Aruba Link Budget Calculator
  • 1.  Aruba Link Budget Calculator
    Posted Oct 17, 2011 10:53 PM
    Hi All,
    Does anyone have or uses a specific Aruba Link Budget Calculator. Where you can select different model of Aruba and Antennas and it will automatically compute for EIRP ,RSSI ,AVAILABILITY, FADE MARGIN ?
    marlon
  • 2.  RE: Aruba Link Budget Calculator
    Posted Nov 17, 2011 06:34 PM
    Unfortunately we do not have a calculator/spreadsheet with that functionality (11n outdoor propagation is not a linear calculation unfortunately). As of now, your best bet is using the Aruba Outdoor Planner
    https://outdoorplanner.arubanetworks.com/
  • 3.  RE: Aruba Link Budget Calculator
    Posted Dec 01, 2011 12:32 AM
    Hi Johward,
    Thanks!
