Hi Hartmut,
Did you clean the fiber connectors before you started using them?
Did you measure the RX with a optical power meter? The RX value of the transceiver might not be 100% correct.
Which switch do you use? If the LRM 100% supported in it?
This value looks too low to give a good link!
