Aruba-master hostname change to aruba-conductor
  • 1.  Aruba-master hostname change to aruba-conductor
    Posted Sep 14, 2022 04:16 AM
    I am preparing to upgrade a campus system from AOS 8.8 to 8.10.0.3. The release notes states that the factory-default of APs running 8.9 and above will use target hostname aruba-conductor instead of aruba-master. The APs on the system are currently set to look for DNS name aruba-master. Therefore, when I upgrade to 8.10.0.3  will the APs that are configured to use aruba-master continue to work? Or do I have to change the AP defaults in advance to use the IP address, or alternatively setup DNS to use aruba-conductor after the upgrade reboot?
    Kind regards
    Coffeezz
  • 2.  RE: Aruba-master hostname change to aruba-conductor
    Posted Sep 14, 2022 05:18 AM
    If you manually configure the lookup to aruba-master, then things should operate as expected. To be on the safe side, you probably want to have both aruba-conductor and aruba-master resolvable on your network. I would create new 'A' records for aruba-conductor.yourdomain, and change the aruba-master in a CNAME to aruba-conductor. In that case you cover all scenarios, including if you add a factory default AP running older firmware at any point.
  • 3.  RE: Aruba-master hostname change to aruba-conductor
    Posted Sep 14, 2022 05:53 AM
    Thank you for your advice
